Question about Philips Magnavox 51MP392H Rear Projection Television
52in tv How do you drian the Liquid bad picture
  • Philips Master
  • 8,617 Answers
Go to the following link it is a detailed proceedure on how to change the coolant on Phillips/Magnavox projections, but they are all basically same for many projection units. Hope this helps you out. let me know if you have any questions. http://www.iwaynet.net/~nesda/ProjCool.pdf
Posted on Jan 07, 2008
6ya staff
SOURCE:
Picture does not fill the screen
Check the picture settings. Refer its user manual for details. To download the user manual, click here.
Jun 06, 2012 | Sharp AQUOS LC-52D62U 52in Widescreen LCD...
I have a Sharp 52in model LC52D62U.The (on) light blinks on an off 2 time an the (opc) light blinks on an off 5 times. Can you tell me what this code meanes. If that is a code.I can not turn the TV on. IT...
yes , the problem on ur tv is the main signal board , when this board goes bad the opc light blinks , i have fix like 20 tv with this problem , now to order the right board u most look at tuner inside ur tv and get a 4 digic number follow by word main , by replacing this board would fix this problem on ur tv
Dec 15, 2010 | Sharp LC-52D62U 52 in. LCD HDTV
I have a RCA D52W19 52in Rear Projection HDTV and the light flick
Deflection board , its bottom board to the left has FBT flyback transfomer CK capacitors cp 150 2200uf 16v use 25v and two more cp114 cp120 220uf 35v if cp 150 is puffed up on top it is bad replace All 3 capacitors for parts call Mats Electronics 1-800-628-1118, also For Deflection replacement board Call Encompass Electronics Parts 1-800-638-3328
Nov 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
52in dlp lg tv has no picture
i checked the power supply board but still nothing
May 19, 2009 | LG RU-52SZ30 52" Rear Projection...
Sony xbr-52in projection tv show double picture's
It sounds like a convergence problem. A fairly common reason for thisproblem is the convergence chips have failed. They are usually referredto as "STK" chips since the model number of these chips start with STK.I will put a link to another part of this site where someone has postedpictures and a link where to get the parts should you decide to fix ityourself. Look at Ecullier2012's posting. Jean's posted site will notfix this problem. Hope this helps you out. Let me know.
http://www.fixya.com/support/t1684874-screen_blue_green_green_red_outlines
Mar 08, 2009 | Sony KP-51HW40 51" Rear Projection...
RCA 52in stretched picture
1) Do you have a cable box or converter box hooked up to the TV? 2) How old is the TV ? 3) Is it a rear projection TV? 4) Does this happen when watching a DVD, Game Source, VCR Tape?
Feb 23, 2009 | RCA P52926 52" Rear Projection Television
Picture problems
try this push left or right arrow key on remote to change the fomat
Dec 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No sound on my 52in jvc tv
i unplugged my tv and when i turned it back on had picture but no sound and all cards are still in tack.
Jul 31, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Beeping sound when tv is pluged into wall. no picture or sound
is it beeping or cherping ,cherping it the power supply trying to run.power supply poss.faulty
Jul 29, 2007 | RCA P52926 52" Rear Projection Television
Philips Magnavox 51MP392H Rear Projection Television Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
