V, Inc. V, Inc. VIZIO RP56 Rear Projection Television
Problem for V, Inc. V, Inc. VIZIO RP56 Rear Projection Television
My daughter was messing with the remote and now it
By stacyfinchum on Nov 10, 2009
My daughter was messing with the remote and now it is broken. All of the buttons, except power, turn the tv on/off. That's all they do. (volume turns it on/off, channel up/down turns it on/off, power does nothing). And the red light stays on. What is happening and how do I fix it? It is a vizio
Solution #1
posted on Nov 10, 2009
Not Rated)
Chu3505
Rank: Guru  Televisions & Videos  Expert
Rating: 85%, 409 votes
Tries take out the batteries,put it back a couple hours later.See if it reset itself.If not,try this website for a new remote 1-800-Remotes Factory original.
Was this helpful?
Yes
No
Popular Solutions for V, Inc. V, Inc. VIZIO RP56
Questions and Unsolved Problems for V, Inc. V, Inc. VIZIO RP56
Do you recommend V, Inc. V, Inc. VIZIO RP56 Rear Projection Television?
Answer
Answer
I have a new 32 inch Vizio Flat screen Tv bit the remote willl not work. The same remote will turn... (More)
Answer
I need to find a replacement color wheel for the RP56 none of the distributors contacted have stock.... (More)
Answer
I have a Vizio rpt50v Rear projection tv that will power up and then go off. I assume there is... (More)
Answer
Whenever I watch a dvd or play on an xbox, the volume is much, much lower than when watching regular... (More)
Answer
When i hooked up my vizio tv to direct tv using hdmi the volume is very low. Is there a fix for... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For V, Inc. V, Inc. VIZIO RP56...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
