Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
Horrible grinding/buzzing noise when spinning game
By jessicalynn3 on Nov 10, 2009
horrible grinding/buzzing noise when spinning game discs and does't read them 50% of the time, but plays dvd movies fine with no buzzing/grinding noise no red lights at any time
Comments:
Nov 11, 2009
- got it torn apart blew it all out with canned air made sure the magnet was still attatched as described in the other solution posted. thinking about just replacing the drive. it is a hitachi model gdr-3120L as stated on its sticker. none of this type appear on ebay only samsung toshiba or benQ brands appear and they state that vthey must be "flashed" before they will work. what does it all mean? can my drive be replaced with another brand? can you "flash" it yourself?
Best Solution
posted on Nov 11, 2009
Very Helpful)
XboxRepKit
Rank: Guru  Microsoft Expert
Rating: 93%, 32 votes
you need to strip down the drive inside the 360, it is possibly an Hitatchi 78, 79fk or 79fl drive and they are notorious for the spindle magnet coming loose. Take the screws out of the drive and take the top off, look underneath, is there a little round silver magnet stuck to the middle of the white plastic?
if so take it off, and stick it back intot he bottom drive spindle (you should be able to see where its come from). i use a tiny amount of superglue and remember not to put it back together straight away as the glue fumes 'can' damage the laser eye.
Linda xx.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks for the info. will give it a shot this weekend " - jessicalynn3
Solution #2
posted on Nov 10, 2009
Helpful)
repairtech99
Rank: Guru  Microsoft Video Games  Expert
Rating: 91%, 155 votes
It the cd drive hub or the spindle motor pad is dirty.
It isn't clamping the disk firmly so when the drive
speeds up or stops abruptly the disc continues
to spin , it shouldn't cause surface damage to
the cd but it sounds like hell .
If you disassemble the xbox and the cd rom
drive ,clean the the hub and spindle motors pad
this should remedy the noise problem.
Also there is the possibility that
the hub magnet came loose this
would decress the clamping force
of the hub, than you would need to
snap the round magnet in the Hub
back in to place . if get there
let me know and ill explain further
if you have any questions just comment and ill respond
Rob
Was this helpful?
Yes
No
Asker's Testimonial
" i'm more of a camshaft and piston guy but i'll give this a whirl you make it sound easy. if I get stuck I'll ask again later, thank you!! " - jessicalynn3
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
my xbox 360 has one red light. how can i fix this
Answer
2 red lights on my sons xbox and something making loud noise when trying 2 run /its 2 years old!!!
Answer
I wanted to know how to fix my DvD Rom,it's not in straight and I want it fixed so I don't have to... (More)
Answer
Whilst playing a game, the colour changed to a pinky colour. I switched the console off and there is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Xbox 360 Console:
Top Video Game Console Experts
Rank: Guru Guru
Solutions: 416
Experience: From previous experience, research, schooling, and studying the work.
Ask Me
Find more Video Game Console Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
