Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
That is usually the evaporator fan motor ($30).
Check to be sure you can get a replacement fan first, they last about 4 - 5
years. Available from a parts supplier or electric motor company.
Unplug fridge. Located usually in top of freezer behind a vented cover
plate. Remove cover, remove screws holding fan in, may have to cut wires.
Replace with new motor, make sure the fan spins the same direction (CW OR CCW) as your old one, if you don't know which way it should spin then be sure it pushes air into the freezer area and
doesn't spin backward drawing air from the freezer area.
Jenn Air freezer (side by side) does not 'automatically defrost" now, is there a heating coil...
(More)
Jenn Air freezer (side by side) does not 'automatically defrost" now, is there a heating coil or something that could have gone out? Or how do I test what's wrong?, I'm tired of defrosting that thing ever 3 or 4 weeks. If you have pictures/diagrams that would be great too. I'm not a repair man or mechanic just an 55 yr old lady who can't afford repairmen & enjoy trying to fix things myself. Thanks Barbara
makes percolating sound only when freezer door is closed. It stops making the noise when door is...
(More)
makes percolating sound only when freezer door is closed. It stops making the noise when door is open and interior light on
Ice maker has been working sporadically for a couple of months. Now the fridge is leaking water from...
(More)
Ice maker has been working sporadically for a couple of months. Now the fridge is leaking water from the bottom of the refrigerator.
