MSI K8T Neo-FSR Motherboard
Problem for MSI K8T Neo-FSR Motherboard
Power suppy fried, now new power supply will not power up
By kj42099 on Nov 10, 2009
I replaced the power supply. But now all I get is the red hard drive light is solid. The green power light is blinking. The PC will not boot up. The new power supply doesn't have the extra plug that was on my mother board. It was plugged in right by the yellow IDE#3 slot(PNF AN-1). I'm not sure what that did. It was a blue and black wire. But I looked at 2 different power supplies and neither have the 2 wire plug. I am afraid my board is no longer good...please help.
Best Solution
posted on Nov 10, 2009
Very Helpful)
Mustang_Momm
Rank: Master
Rating: 91%, 4 votes
a 450 watt power supply will have the extra pins your talking about if this is a newer pc if not you will have to buy older used one on ebay or something to get what you need
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" I asked and even brought the old power supply to best buy. They don't have a clue.Thanks for the help " - kj42099
Solution #2
Not Rated)
lchand1958
Rank: Guru
Rating: 91%, 169 votes
HI:
Not all power supplies have that tiny, 2 pin plug. All it did was tell the motherboard that the power supply fan was running.
You might have problems other than a failed power supply, but the one way to check is to just plug in your new power supply to the motherboard only, and leave all the plugs disconnected from all other drives. pull the coin battery off the motherboard for a couple minutes, or clear the CMOS with the jumper, if you know how. Once you get the motherboard to POST, or power up with the new power supply, then turn it off and connect your drives, one at a time. Hopefully you will figure out what is not working
Was this helpful?
Yes
No
Popular Solutions for MSI K8T Neo-FSR Motherboard
Questions and Unsolved Problems for MSI K8T Neo-FSR Motherboard
Do you recommend MSI K8T Neo-FSR Motherboard?
Answer
Answer
Mobo Samsung Harappa-12 can I have a manual pls? pdf or something my email add is... (More)
Answer
I don't know which poles to put the wires on from the power switch to my ices 003 b motherboard
Answer
I have a promax x chip and i want to fit it to my 2008 citroen c5 1.6 diesel. I am not sure of the... (More)
Answer
para que es la conexion rca al lado delos puertos usb traseros
Answer
Early Chipset initialization comes on on the D-link. I replaced the the Pwr supply as it was bad but... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboards Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
