Question about Mitsubishi VS-45609 TV
Vs-45609 my vs-45609 red can is out of adjustment(not the focus) it is curveingon right side of screen, is there a adjust ment?
  • 4 more comments
  • scottcross63 Jan 06, 2008
    thankyou, i already did a convergence reset
  • Anonymous Feb 25, 2008
    I REPLACES THE ICS WHERE IS THE FUSE THAT BLOWS THAT ALSO MAKES IT TO WHERE YOU CANT ADJUST THEM
  • tilton_larry Mar 13, 2008
    my tv's red convergence is on the left side of screen
  • Anonymous Apr 01, 2008
    i need to knoww were is the covergence is on the board
  • taboogrl Dec 07, 2008
    On my Tv i see green and blue swirls down the middle. i can see the tv but in red. how do i fix. i already did the conversion reset didnt work.please help
  • tavis607 Apr 12, 2009
    my red convergence is off on both sides and won't adjust left nor right but they will go up and down. Nothing is working!!!!!!!!!!!
    President:
  • 4,402 Answers
I think you convergence ic are bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 06, 2008
    Genius:
  • 1,153 Answers
You can do a convergence reset, see ctechnicians.com
My Mitsibushi VS-45609 tv/ convergence and picture size acts up once in a while
Try to download the repair manual to your set from internet. It sounds that you have to get into its service mode adjustments. All details are in the repair manual.
Apr 21, 2012 | Mitsubishi VS-45609 TV
Red horizontal curvy lines
You need to turn the voltage on the red tube down slightly, also you would need to adjust focus to compensate for the lower voltage to the red tube. On the left and right bottom side of speaker cover are two round covers, take them out and there are 2 1/4" hex screws take them out carefully take cover off, there is another service cover same hex screws remove. You will see the focus block on the right side, tubes are labled on block. 2 knobs for each tube. Make voltage adjustments while tv is on a black screen, then for focus, turn color all the way off in the menu, and adjust focus until it looks right in black and white. These adjustments should only be very small; if alot of adjustment is needed, you may have other issues.
May 29, 2009 | Sony KP-51WS500 51" Rear Projection...
Convergence problem
YES YOU CAN DO IT MANUALLY WITH THE SCR,IF IT WERE ME ID TRY DOING IT.THE FRONT SPEAKER GRILL COMES OFF,YOU CAN GO FROM THEREEWS,BUT YOU MAY SCREW IT UP MORE THAN BEFORE
May 21, 2009 | Mitsubishi VS-45609 TV
Focus
On CRT projectors, there is a part called a focus block with adjustments for each picture tube. A sudden loss of focus is pointing to something else, a change in the high voltage. Poor high voltage regulation will cause a loss of focus. If your loss of focus has been gradual, you can try adjusting the controls on the focus block. The focus block is usually a square or rectangular block, usually mounted on the front behind a panel or on the rear behind a panel. it will have a series of red wires coming out of it. There usually are 6 adjustments on the block, 3 for screen voltages and 3 for focus. Be sure you adjusting the right ones, they are usually labeled.
Nov 09, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS 45609 Blue Shadow On TV Picture
you need to replace the convergence IC STK393-110 you can get it as well as picture installation instructions as well as free online tech support at the link I posted very good prices
http://servicemanuals.vstore.ca/
May 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Samsung TXS 3082 HDTV focus problem
if there is no focus adjustment hole in the back of the unit it will have to be taken into a shop where a pro can adjust your vs and va voltages.
Mar 28, 2008 | Televison & Video
Problems with a Mitsubishi Big Screen
Where did you adjust the red and blue?................Did you remove the speaker grill cover and the access panel to get to
the screen control adjust? Do not adjust focus..........make
sure you turn down ( CCW ) the red screen control a little....
is that any better...........?...................T.
Dec 03, 2007 | Televison & Video
Blue, red and green ghosting, curves in picture
convergance amp ic bad
Oct 30, 2007 | Mitsubishi VS-45609 TV
Mitsubishi VS-45609 TV Logo
296 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
