Question about Cobra 22 CHANNEL 2-WAY RADIOS
Cobra PR4700WX -none of the controls work
Is there a common fix for this? When I turn the unit on, no matter what button I press, nothing at all happens. Is there a lockout that's happening or is this a more serious problem?
  • 1 more comment
  • Watermonkey Jan 07, 2008
    Thank you for the troubleshooting assistance. Based upon what you wrote, I guess I'll be taking it in to have a technician look at it, as none of your suggestions changed the behaviour (or lack thereof) of the radio.
  • dwags Jan 18, 2008
    i have the same problem only mine is a pr4750wx. holding the unlock button does not work, none of the buttons work. im ready to toss it out. any suggestions???
    Thanks
    D.
  • jake47 May 11, 2010
    need info on pr4700wx cobra its stuck on vibrate
If you find that the LOCK/MODE button does not correct the problem, I have discovered that the microphone button on the inside has a contact patch mounted on the board. This contact patch is like a piece of scotch tape with a metal dot in the center this slides off to the side and leaves the MIC deppressed continuosly which in turn will lock the radio. I have found this on several radios. Once you center the patch place just a small amount of super glue to the edges and yo will have no more problem
Posted on Nov 28, 2009
    New Friend:
Your suggestion to check the alignment of the tiny disk on the TALK button switch was spot on. I was ready to throw away the radio, but five minutes of tinkering and it is working like new. Thanks!!
Posted on Feb 28, 2015
    Brigadier General:
  • 6,966 Answers
Your concern might be a simple case of "the radio is in locked mode" which can be verified with the presence of a padlock icon in the uppermost row of icons.
If it is so, turn it off by pressing the Lock/Mode button for a couple of seconds or till you hear a double beeping sound and/or the lock icon disappeared.
If there is no lock icon and none of the buttons will work, try to do a hard reset by removing the batteries and try again.
If none of the above will be corrective, your unit may require the services of a qualified communications technician since the problem may either be firmware or touch pad/logic circuitry.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 06, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
I want to thank jimp19550 for the tip ( on the microphone button on the inside has a contact patch ). That was the exact problem on my radio. I re-centered the contact and it was FIXED !!!
Cobra PR4700WX -none of the controls work - cobra-pr4700wx-none-controls-work-lgj4ywxs5nq5gizwefkzvzxa-1-0.jpg
Posted on Feb 04, 2016
This suggestion fixed the problem, thanks! (Ptessing the lock/mode button for a couple of seconds...)
Posted on Jul 18, 2008
My Advantium 120 microwave shows the time, but none of the buttons respond to being pressed.
Try turning it off at the power switch,leave off for several seconds then switch it back on, it may reset the control unit, if not take it to a repair outlet,
May 27, 2015 | In Microwave Ovens
My TI-89 Titanium is stuck on the main screen and no matter what button i press nothing happens. I have tried changing out all of the batteries and nothing is working.
Hi
when you turn on the Calc press the 2nd button and if the busy indicator is on its and hardware problem or if none of the keys is working
let me know if you want to fix
ecrdn@yahoo.com
Jack
Jun 26, 2011 | Texas Instruments TI-89 Calculator
Whirlpool HE WFW9200SQ00 is Dead
control unit dead, replace main control and possibly user interface. Sorry this is very common failure on whirlpool.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No Auto Squelch on Cobra PR4700WX
Yes sir, when u will open the set u can find two potentiometers , one is for tranmitter another for receiver . Try adjusting the same ( second radio should be transmitting ) do not switch one radio without antennae it may burn ..
Regards
raj/
Dec 24, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
COBRA PR4700WX
Hello horndog78,
Your radio may be locked. You can confirm this by looking for a icon of a padlock on the screen.
To toggle the lock on and off hold down the LOCK/MODE button for a full two seconds until you hear a double beep.
Best Regards,
Ken
Go Ahead. Use Us.
May 02, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Help
Hi again,
It would seem that you posted twice. As responded to in your other post, the manual is here.
Cheers.
Mar 16, 2008 | Cobra 22 CHANNEL 2-WAY RADIOS
Ilo-32hd
I'm having the same problem. And yes, it's probably from static shock because I shocked the tv when I went to turn it on the other day. Now nothing, it goes on but none of the button work. Is there anything we can do about this? Help!
Feb 29, 2008 | iLO 3200 32 in. LCD Television
Long range mode
For the Cobra PR4700WX:
The user's manual is available here
To turn on/off the long range mode - (If you are referring to low & high power); Press and hold the Hi•Low/Enter button for two seconds.
Alternately, if you are referring to the Light/Max Range (receive sensitivity), 3 options:
1. To briefly turn off auto squelch - Press the Light/Max Range button for less than five seconds. If you hear two beeps, you have turned the maximum range extender on.
2. To turn maximum range extender on - Press and hold the Light/Max Range button for at least five seconds until you hear
two beeps which indicates the maximum range extender is on.
3. To turn maximum range extender off - Press and release the Light/Max Range button or change channels.
Probable reason that "fishing was all right but for hunting there is to much static" is becasue these radios operate on line of sight principle. Anything that obstructs the linear view would reduce signal strength/range. There is not that much obstruction when fishing compared to that when hunting in the woods or rough uneven terrain.
Please note that when using Channels 1 through 7 and 15 through 22 on high power, the Hi icon will be visible on the display. When using those channels on low power and on Channels 8 through 14, the Low icon will be visible on the display.
For the Cobra PR3500DX:
The user's manual is available here.
The transmission message icon off when not in use - this icon will only display if the radio is receiving something or if your are pressing the PTT button.
The other three the transmission signal is on at all times - indicates that either you are transmitting (unlikely) or the radio is in constant receive mode (most likely). I would venture a guess that the Auto Squelch is switched "OFF" or Maximum Range is switched "ON"
Both the 4700 & 3500 has Power Saver and it is a built-in feature. Your radios have this unique circuit designed that extend battery life. If there are no transmissions for 10 seconds, the radio will automatically switch to Battery Save mode and the Power Saver icon will flash in the display. This will not affect the radio’s ability to receive incoming transmissions.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Nov 07, 2007 | Cobra 22 CHANNEL 2-WAY RADIOS
Open Questions:
Cobra 22 CHANNEL 2-WAY RADIOS Logo
995 people viewed this question
Top Cobra Radio Communications Experts
Steve
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
