Question about Hotpoint RB787 Electric Kitchen Range
Oven Door will not close properly
I believe the springs on my oven door have weakened to the point where the door cannot close completely. The oven light does not go off. Is the solution replacement of the spring?
Oven door will not close completely. Baking and roasting takes twice as long as required.
Two janitors have tried without success to fix it
  • 3 more comments
  • Anonymous Jan 30, 2008
    My oven door won't stay closed.It is a 15yo Chef Versatile wall oven.
    It appears that a spring loaded weight has seperated from the hinge .We are able to remove the door easily ,but then internally we hear a weight sliding about,and the hinge is in free fall.
    Does anyone know what I can do about it ?:
  • Anonymous Mar 11, 2008
    Oven door will not close tight
  • governor61 May 05, 2009
    I have a kenmore electric range and the door does not close completely - the light remains on. I have removed the face of the door and exposed the springs and hinges. I see no problem with the mechanism. I am going to grease the hinges and I may replace the gasket but I could use any suggestions that are available Paul B
  • Anonymous Mar 13, 2014
    Bottom oven door does not close fully like the top one
  • Anonymous Mar 19, 2014
    oven door
Ive got the same problem, but im only 12 and im at home alone... my parents will be home in a wile and unless i don't set the house on fire, i'll see wat they do 2 fix it!!
Posted on Mar 25, 2010
I havent got a clue
Posted on Mar 09, 2008
Oven door will not close the whole way
Your oven door hinges(s) are broken, the springs that hold the door closed inside the hinges are either weakened or their mounting points have become worn.
You need to purchase a pair or replacement hinges which you can fit yourself if you have some basic mechanical skill. Don't try to just replace one side if you determine which side has failed as the extra strain put on the old hinge can cause the door to twist and break the door.
Mar 05, 2012 | Tappan Kitchen Range
Door will not close completly
When you say "oven door will not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 08, 2011 | Ovens
Oven door won't close completely
You will probably have to replace the springs I doubt if they can ve fixed. you can open the door all the way and you will see a hole in the spring just inside the door. you can stick a nail in that hole, both springs that will hold the door open and you can lift the door out and check the springs I will tell you to have patience its not easy.
Apr 21, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
We have a 30 in prostyle electric double wall oven - the oven takes forever to preheat and the doors do not seal tightly when they are closed.
Hello- Many ovens use spring-loaded hinges to carry the weight of the door. Over time, these springs weaken or the hinge gets bent just enough to not fully close door. The door gasket can also become flat and stiff, compounding problem. Any small gap releases heated air, and oven will not heat up properly. Replacing the door springs should solve problem.- Thanks -Ed
Mar 14, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
The oven door (Model SMW272) does not close completely. It may need an adjustment or a new seal?
Generally speaking, if a oven door does not close properly, and it is a drop down door, then it usually due to weak springs in the hinges.
There is no adjustment provided, so the only solutiom is to replace both door hinges.
Please rate my nsolution.
Jan 28, 2010 | Thermador SMW272 Electric Double Oven
Moffatt double oven 4175 lower oven door springs broken
My problem was not with an Amana single oven but aMoffatt double oven ! However I have now decided to buy new.
Oct 31, 2009 | Amana AEW3530DD Electric Single Oven
Don't buy Bosh. This is a common problem with them and they are not interested in a fix (ie a thinner door seal would help or adjustment to springs...
Feb 11, 2008 | Ovens
Hotpoint RB787 Electric Kitchen Range Logo
782 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
