Pressure Washers
Problem for Pressure Washers
Generic problem for all Pressure Washers
My pull cord to my pressure washer is har...
By thank_you_je on Nov 10, 2009
My pull cord to my pressure washer is hard to pull and it's not starting. Why? This all started after I tried to start it without the water on while attempting to start.
Solution #1
posted on Nov 19, 2009
Not Rated)
twinman007
Rank: Guru
Rating: 89%, 34 votes
take out the spark plug and trying pulling it , if its still tight then you may have seized your pump ) , put a rag over te spark plug hole as there may be fuel/oil mix in the cylinder , check the oil in the engine , check the oil in the pump ( look for milkey white , if found then your pump back seals have gone )
Was this helpful?
Yes
No
Popular Solutions for Pressure Washers
Questions and Unsolved Problems for Pressure Washers
Answer
do all troy bilt pressure washers have brass pumps?
Answer
Honda Powerstroke Pressure Sprayer: How do you drain any water that might be in the Pressure Washer... (More)
Answer
engine will not turn-over. It is a Honda 11 HP, OHV on a Karcher Pressure Washer. It was running... (More)
Answer
my pressure washer will only run with the choke pulled out. I have a **** poor mannual. the gas line... (More)
Answer
need packing kit for 2600psi item #15794d serial 1006 17273
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pressure Washers:
Top Pressure Washer Experts
Rank: Guru Guru
Solutions: 3968
Experience: ten years experience,school trained,own business
Ask Me
Find more Pressure Washer Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
