Soooo... My LG 42 MU-42PZ90C comes on, but its like all the pixels aren't being actived at once....
(More)
Soooo... My LG 42 MU-42PZ90C comes on, but its like all the pixels aren't being actived at once. Like there are all the colors, just few pixels per inch. and its really random... Also on the back, FD740 LED is flashing in the back. I looked all over for defective caps, but I did not discover any. unless I de-solder and test their capacitance, there really isn't a way. left in circuit will give me a false reading. Does anyone know the exact reason for this? The flash LED code? a service manual perhaps? Thanks
the color just went out on my tv - it is only showing in black and white. Is there anything I can...
(More)
the color just went out on my tv - it is only showing in black and white. Is there anything I can do?
At first my D52W15 Powered on and cycled until it finally came on, but now it cycles 3X's more and...
(More)
At first my D52W15 Powered on and cycled until it finally came on, but now it cycles 3X's more and then goes completely out, and wait for a few minutes and same thing occurs, Is it safe to assume that the Main Power board has failed and it should be replaced, also I have soldered some circuitry on P.C Mainboards in the past, can this board be repaired with simple soldering of fuses etc.. ? Ultimately I will just replace the PSU First-Off, then repair the Original PSU with Fuses,Transformers and/or Capacitors later on in my spare time .. From reading the previous post's above it appears this is a common problem for this brand, although I think it comes down to the circuitry within the last 3-4 years, it seems more problems occurred within the last 5 yrs with bad Caps (Dell) and bad Solder along with heat issues (Xbox 360) within the line of P.C's and Gaming Consoles. Please Advise, if by experience you feel as if it's a heat issue, I will recourse and plan for Cooling measure's.. Thank You for your knowledge in advance... RJ
will not start even after lamp replaced. Lamp turns on. Green lights on the front turn on/off switch...
(More)
will not start even after lamp replaced. Lamp turns on. Green lights on the front turn on/off switch brinks for a while, then goes off.
