Kenmore 63942 Dryer
Problem for Kenmore 63942 Dryer
Dryer won't heat and the timer doesn't move. It
By libbydiane on Nov 10, 2009
dryer won't heat and the timer doesn't move. It runs forever with no heat.2 different problems?
Clarification Request
Posted by aasc on Nov 10, 2009
If your running it on auto dry , and not getting any heat , it will continue to run . If using on timed dry , then the timer will shut off . Need brand and model number to help you . Only 1 problem : no heat .
Solution #1
posted on Nov 10, 2009
Not Rated)
salde386
Rank: Guru  Kenmore Washers & Dryers  Expert
Rating: 94%, 57 votes
if you have timer on time dry and it doesn't move timer is probably bad, if you have it on auto dry or some say more or less the timer will not move if there is no heat
Was this helpful?
Yes
No
Solution #2
Not Rated)
cmm19987
Rank: Wiz  Washers & Dryers  Expert
Rating: 78%, 18 votes
Could be the tumbler. Also check the vent coming from back of dryer make sure it is not clogged. And as for the timer it could be bad you might have to move it a little up or down because it is probally sticking. But would not cause the clothes not to dry.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 63942 Dryer
Questions and Unsolved Problems for Kenmore 63942 Dryer
Do you recommend Kenmore 63942 Dryer?
Answer
Answer
kenmore dryer works good first load but wont start for second load untill it sits awhile and cools... (More)
Answer
Kenmore Elite Dryer Model# 110 70932990 door keep popping open,stoppping the dryer
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryers Experts
Top Washer & Dryer Repairmen
in San Mateo, CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
