Question about HP Pavilion dv9000z Notebook
3 beeps at start
My laptop started to freeze often, Im a second life gamer... I purchased my laptop in nov.06... new years eve 08 i was on computer when the screen went white... next morning i tried to turn the computer on and got 3 beeps one long beep 2 short beeps ... when i turn the computer in there is no screen and gives a clicking sound, turns off and makes clicking sounds again if i unplug and take out battery sometimes it boots up, hp support said to update bios, did it and still nothing!!.... please can someone help me!!!
  • 2 more comments
  • Anonymous May 23, 2008
    no display and 3 beep
    no display and 3 beep all led on poshition,,,,,,,,,,
  • Anonymous Feb 15, 2009
    3 beeps no signal on screen
  • Anonymous Mar 22, 2014
    i tried to turn on my laptop and it turnt on but nothing came on the screen, it beep for a few seconds and turnt off. hp compaq nc6400
I had the same problem with the beeping, i changed the rams and now its working fine. works for me, good luck
Posted on Jun 17, 2008
This is an HP problem. You will have one year from waranty end to correct this problem with them.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=ca&dlc=en&product=1842078
Good luck, happened to me too!
www.NathansPianoMusic.com
Posted on Jan 22, 2008
Gosh... I'm researching the same problem. I fear the solution lies in sending it back to the manufacturer under the wrranty. Is it an HP dv9000? That's mine and that's what I'm about to do.
Posted on Jan 11, 2008
The three beeps are your key! The post test are failing when you energize. Check your BIOS manufacturer to decode the beeps. The sequence is the main thing. Ask them to check post and tell you what the failure is. There are some books out there that also tell you what the beeps are calling as the failure.
Posted on Jan 07, 2008
  • 89 Answers
No video is typically caused by bad CPU, bad memory or obviously, bad video card. The White screen is because there may be somehting wrong with video inverter. The clicking sound may be related to the hard drive. Try removing battery and AC plug, then press and hold power buttton for 10 seconds; I may be wrong on this, you may want to double check on Hp's website to see how to reset BIOS.
Posted on Jan 06, 2008
If you have your home work or files in your laptop and you can't save it or you want to remove to another PC then
I have solution for you!!
if you stop the fan by inserting anyting to sop it cooling the CPU then the laptop shuts itself down,
press power button again n again after few minutes ou will see the laptop works normal,
if you want to use it like this just don't shut it down when you finish,
leave it on sleep mode.
Posted on Dec 13, 2008
2 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: 3 beeps at start
hmmm...that's not good. works fine with no battery. I suspect your motherboard may be taking a vacation from working soon.
got backup for your HP?
Posted on Feb 12, 2008
Iver Johnson Hammerless .32, 5 shot. Nickel plated with pearl grips. Serial number 418. PAT AUG 25 96 & NOV 17 08 (or 98). No safety on trigger or behind it. Can anyone give me info about this?
Iver Johnson Wikipedia the free encyclopedia
not much info out there
could it be a reproduction ?
cant find one for sale today
source wiki
First Model (1895–1896), single post latch
Second Model (1897–1908), safety lever added to face of trigger
Third Model a.k.a. New Model (1909–1941), no safety lever on trigger, adapted for smokeless powder
38 cal hammerless
Nov 11, 2016 | Optics
How do I attach this monitor to my laptop to use it as a second screen Please?
How do I connect my laptop to an external monitor - Page 2 ...
h30434.www3.hp.com > Laptop & Notebook > Video/Touch
May 6, 2013 - 10 posts
I have a pavillion dv5 2070us and the screen is cracked and I can't see ... I have a pavilion dv6, can someone please tell me the order of the menu ... 06-01-2013 08:19AM ... Once I connected my laptop to the extra monitor, the screen on my extra ...Connect your second monitor while the computer is on. 2.
The HTG Guide to Adding an Extra Monitor to Your Laptop
www.howtogeek.com/.../the-htg-guide-to-adding-an-extra-monitor-to-y...
Aug 7, 2014 - Adding extra screen space to your laptop, however, can be quite a bit trickier. ... If you're looking to do the same, to add a little space to your laptop ...Playing Minecraft on the second monitor was a smooth experience with no drop in FPS. ... Because the AOC does what it does so well, we'll use it to highlight ...
AOC E1649FWU 16-Inch 1366 x 768 16 ms LED LCD Monitor
www.amazon.com/AOC...Monitor/dp/B005SEZR0G
Amazon.com, Inc.
Rating: 3.8 - ‎1,067 reviews
Jan 04, 2016 | AOC 936sw 19" Widescreen Lcd Monitor -...
Monitor cold start issue only as #2 monitor
The start up problem is common and will only get worse. Call Samsung as these monitors have a 3-year warranty. No receipt? They will accept your word regarding your purchase. I have two that failed exactly the same way. I called 1-800-SAMSUNG and they gave me the choice of an exchange pair sent directly to my house (requiring a temporary credit card deposit) or by having the exchange pair sent to the UPS store where I would swap out my bad units. No receipt. They merely asked me when I purchased it so they could have it for their records. Manufacture dates such as your (March '06) and a purchase of September '06 are not far fetched at all. .
May 19, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Compaq eve n610c
i think you need to take your laptop to computer shop for repairing. your system's operating system might be crash so you need to do either recovery or do a fresh installation of opearting system by putting the os cd in your cd/dvd drive.
Jul 12, 2008 | Computers & Internet
3 beeps at start
Feb 12, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
42HN66
i would ask for a refund or exchange.
Dec 29, 2007 | Toshiba 42HM66 42" Projection HDTV
Won't honor warranty
Unfortunately, Microsoft has the final say on warranty issues. Speaking as someone who presently works at the customer service desk at one of the major retailers, it's not surprising that the store staff couldn't help you.
It's possible that the unit you have was sold once to someone else, then returned to the store and re-sold to you. If that's the case, Microsoft will say the warranty started the day it was sold the first time (even if the first owner never opened the box), since they get information from the retailer when they scan the serial number on the box at the time of sale. Also, I'm afraid it doesn't matter when the defect occured--what matters is when you call them; so screenshots etc. won't be a help in this case.
Try calling Microsoft again, but ask for a supervisor. Be polite, but insistent. Saying, "I know that your system says my warranty is expired, but I'd like to speak with your supervisor about that," might work. If they try a line like "but my manager will say the same thing," then respond with "I'm sure that might be true, but I'd still like to have him or her say it directly to me." Try to convince them to allow you to fax them a copy of the receipt with the accurate purchase date. If you can convince them that they're wrong, they'll probably make an exception to allow you to return it even though it's now well into December.
Dec 10, 2007 | Microsoft Xbox 360 Console
HP Pavilion dv9000z Notebook Logo
3,229 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
