Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Hotpoint FDW80( A10 Appears ondisplay half way through cycle)
Got a hotpoint fdw 80, it gets halfway through a cycle then A10 appears on the screen, Any ideas how to fix this problem?
  • innisent Aug 24, 2008
    I have the same problem
  • andy270166 Dec 23, 2008
    hi mate do you no what a09 fault code is
Here are the fault codes for your machine...
Fault codes for LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water
  • Hope this helps?
    Posted on Feb 05, 2008
    I had the same fault. After searching for advice from various websites I tried using cheaper tablets and filling the salt dispenser. Instead of using the latest Finnish tablets I changed to Daisies from Tesco. Have since completed over 80 washes without the problem recurring.
    Posted on Mar 23, 2009
    HOtpoint Fdw 60 goes straight to DEMO mode and refuses to do anything? Any idea?
    Try resetting cycle-Push cycle select and cycle start together till you hear a long beep followed by three short beeps.this will cancel previous selection and allow a new program to be selected
    Nov 10, 2011 | Hotpoint 24 in. FDW60 Free-standing...
    Fdd914 dishwasher error code A10 appears and its not in the booklet
    Hi, the interpretation for error code A10 is: A10 = fill solenoid valve triac closed/open circuit - check valve/ operation - machine drains until level switch resets + 30"
    Now, to try and solve the problem yourself: Turn off the water supply to the dishwasher & remove the hose, Run the machine for several minutes in a normal position. Turn the machine off, reconnect the fill hose, turn the water back on then turn the machine back on.
    If this doesn't solve the problem, then you'll need to call a service person.
    Jun 12, 2011 | Hotpoint-Ariston FDD914 24 in. Built-in...
    Vertical lines/black squares all throughout this 50" TV. Is it worth fixing?
    I have 5 vertical black bars coming down halfway on the screen. Also 1 black square that appears on the lower half corner of the screen. What can I do to get them off? Please respond or call me @(510)938-6237 Shon Thanx!!!
    Dec 27, 2009 | Mitsubishi PD-5010 50 in. Plasma...
    Friend got a hotpoint FDW 80 need to no is it hot water supply or cold?
    Connect your dishwasher to the HOT supply line. The most common method is to connect to the hot water supply line in your kitchen. Before running the dishwasher, it is also a good idea to turn your hot water on to allow the water in the line to heat up. This will reduce the time is takes for the dishwasher to heat the water for the wash cycle and cut down on the cost of electricity.
    Dec 07, 2009 | Washing Machines
    Hotpoint ultima dishwasher fdw 80 will not program comes up DEMO tried switching off at mains to try to reprogram all to no avail any ideas gratefully received
    i connected to hotpoint dishwasher manuals and it came up with my model and how to rectify the problem which following the instructions i solved the problem .
    regards
    ray
    Aug 07, 2009 | Hotpoint Dishwashers
    Error code AL03 on fdw 80 dishwasher
    Hi yes i did post a problem on the " let our experts fix your problem for free " section, so how long is it going to take as the machine is still not working ? please advise asap
    Jan 07, 2009 | Hotpoint Dishwashers
    Hotpoint fdw80 dishwasher
    Faulty heating element. Had the same error and got Hotpoint to replace the element. Error was also confirmed by their engineer.
    Apr 13, 2008 | Hotpoint 24 in. DWF32P Free-standing...
    Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
    1,716 people viewed this question
    Top Hotpoint Dishwashers Experts
    Marvin
    Marvin
    Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
