Home | ASUS | P5PE-VM Motherboard | No function motherboard
ASUS P5PE-VM Motherboard
Problem for ASUS P5PE-VM Motherboard
By jhie_41 on Nov 10, 2009
no function motherboard
Clarification Request
Posted by anonpi on Nov 10, 2009
Was there a question in there somewhere?? JOAT
Best Solution
posted on Nov 10, 2009
Very Helpful)
bhagyavichar
Rank: Guru  Computer Components  Expert
Rating: 96%, 2156 votes
i hope u r a professional in handling viz assembling/disassembling pc(s)..and assuming that the bios has not been flashed in a wrong way..probably itz either a case of loose ram/board short/improper ground/cmos battery..plz do check the following as in order:..
1) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..
2) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
3) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
4) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
5) the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..
the 'oscillator and error amplifier ic', or pwm switching regulator circuit..look for defective protector-transformer/resistance(esp 4.7k)/mosfet..
6) if itz not the smps, then it must b ur main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above 1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector....
always better to seek advise from ur system admin/vendor....
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for ASUS P5PE-VM Motherboard
Questions and Unsolved Problems for ASUS P5PE-VM Motherboard
Do you recommend ASUS P5PE-VM Motherboard?
Answer
Answer
usb device over current status detected shotdown in 15 second. cant acces the bios
Answer
تماااا&#... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For ASUS P5PE-VM Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14723
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
