Question about Philips Magnavox MWR10D6 DVD Recorder
Magnavox MWR10D6 can't record from camcorder wrong channel
Help Please! I am trying to copy from a camcorder to dvd - my camcorder works on aux 2 with my Sansui tv and the magnavox works on aux 1? If I have camcorder hooked up to front of magnavox - I get no picture - if I hook camcorder to front of tv I can't record it.
Thanks
OK...try this...plug your RCA cables from your camcorder into the RCA input jacks on the back of the recorder. If you have a VCR, it can be plugged into the coax input on the back of the recorder. Use the coax output and plug it into a RF modulator (about $20 at Wal Mart). Plug the RCA output cables from the recorder into the RF modulator as well (Don't ask me why, but it seems to work on mine). Connect a coax cable from the RF modulator to the TV. Make sure the TV and Recorder are both on the right channel. The RF modulator will have a channel switch to use channel 3 or 4 on the TV. Make sure the recorder is set to E1 (Rear). You can check this with the channel +/- buttons on the bottom right of the remote. Good luck.
Posted on Jan 11, 2008
6ya staff
SOURCE:
Magnavox 20MC4304 20" TV/DVD/VCR Combo Remote:
A universal remote should solve your problem. You should be able to find one on ebay. You may even be able to find one for your particular TV on ebay as well.
Dec 03, 2017 | Magnavox NE206UD TV/VCR/DVD Combo Remote...
I have been sturggle with remote rca to my tv sharp how i can do that ?
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Jan 25, 2011 | RCA RCRN04GR Remote Control
Need to know if I can record from dvd to vcr on a magnavox ZV420MWB vcr/dvd combo
Magnavox ZV420MWB VCR/DVD Combo
The answer is YES YOU CAN! Take advantage of one-touch recording from videotapes to DVD+/-R and RW discs or from DVDs to VHS tapes. A variety of different inputs also let you record from compatible camcorders, external TV tuners or cable boxes.
CONSUMER ALERT: This model does not have a built-in tuner for recording TV programs and will not record copy-protected tapes or discs. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission's digital television website at: www.dtv.gov.
Feb 15, 2010 | Philips Magnavox DVD/VCR Dual Player
I am trying to sync my sansui tv with my magnavox dvd/vcr combo. I can't figure out what channel the sansui needs to be on to play a dvd. The input button on remote is not working.
Tries buy a new remote this website have a exact or very close to the Original remotes.1-800-Remotes Factory Original.Tries channnel 3 only or 4 only functional for video equipments.
Sep 29, 2009 | Sansui DTV2760 27" TV
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have an old Sansui au999 amp
you can go about this many ways.depending on what you have to work with.are you useing a satilite or cable box?if so assuming they have audio/video out just send the audio to the amp and the video cable to the tv.u could use the aux or the tape in.just put the dvd in the other input aux or tape in.dont matter which.if you dont have a cable box your tv must have some kind of audio out to run to the amp.it can be a rca out or simply a headphone jack.you will need a headphone jack too rca plug cable if you have a headphonejack on your tv.hope i could be of help.
Jan 05, 2009 | Sansui Audio Players & Recorders
Magnavox DV220MW won't record.
You need to plug a red, white, and yellow cord from the red, white, and yellow OUT of your cable or satellite box into the red, white, and yellow labelled VCR IN/LINE 1 on the Philips. To view what you are trying to record, make sure there is another red, white, and yellow cable plugged from the DVD/VCR OUT of the Philips to your television. Make sure the television is on the appropriate source channel (AUX 1, AUX 2, VIDEO 1, VIDEO 2, etc). Then press the VCR button on the Philips. You should now see your cable or sat channel (as long as it's not an HD Satellite box) on the television screen. Press record, and you are on your way. Good luck!
-Tha Mp3 Doctor
Dec 28, 2008 | Philips Magnavox DVD/VCR Dual Player
MWD2205
Please check page-14 of user manual of Funai MWD2205 VCR/DVD Combo for recording in VCR from Camera or some thing else as external source.
Here you can download User Manual for your unit, in case you dont have it.
Need further help, let me know and post here.
Thank you.
Oct 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Need to program a ge universal remote control to operate a Magnavox Total Control System TV
here is the 3 digit codes ive found to try 586, 651, 720, 666, 731, 800
MAGNAVOX ............ 0062 0004 0009 for digit codes
........................... 0456 0183 0226 0288
........................... 0008 0068 0075 0141
Manually turn on the device (TV, VCR, DVD, etc.) you wish to
program.
2. Press and hold the CODE SEARCH/SETUP button on the remote
until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming
(TV, VCR, DVD, etc.). For AUX, press AUX then the device button
you are assigning to AUX. The INDICATOR LIGHT will blink then
remain lit.
4. Enter the three or four digit code for your device using the number
buttons in the GE Universal Remote. After your code is entered the
INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the
POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed,
repeat steps with the next code. If none of the codes listed for your
device work for your device or your brand is not listed,
try the Code Search method described below.
USING CODE SEARCH FUNCTION
If your TV, VCR, DVD, etc. does not respond after you have tried all the codes
for your brand or if your brand is not listed, try searching for your codes by
following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR
3. Press and release the device button for the device you are
programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will
blink once then remain lit. For AUX, press AUX then the device
Jun 21, 2008 | Televison & Video
Philips Magnavox MWR10D6 DVD Recorder Logo
197 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
