My (Homemaker)top loader washing machine does not fill up the water. Water comes in and it goes to the drain straitaway without filling up. What could be the problem.
very simple, your drain hose is below 4 ft, your drain hose should go in the hole between the hot and cold water, if you dont see a hole then it is covered, you need to knock out the hole...
I have Kenmore HE4T and water is leaking out of the front of the drum(between the glass door and the...
(More)
I have Kenmore HE4T and water is leaking out of the front of the drum(between the glass door and the drum
The water is not draining from the machine and the previous load worked fine. At the moment the...
(More)
The water is not draining from the machine and the previous load worked fine. At the moment the machine has water in it and I do not know why it stopped owrking.
