My computer's wireless internet will not connect... I can hook it directly to router and works but the drivers WILL NOT download and install... What do I do??
Try removing the wireless card.Remove the battery and ac adapter first.The wireless card resides under one of the panel on the rear of the computer.Once removed start the computer again.Remove the drivers installed via Control Panel.Power down reinstall the card.Power up if windows find new hardware install the drivers you download.
Good luck
My HP dv9000 will not boot up. Begins to start, but screen black and keys appear not operating....
(More)
My HP dv9000 will not boot up. Begins to start, but screen black and keys appear not operating. Occasionally, will finally boot after powering down and back up
TVAgent.exe entry point not found always pops out. It says: "The procedure entry point...
(More)
TVAgent.exe entry point not found always pops out. It says: "The procedure entry point PowerReadACValue could not be located the dynamic link library POWRPROF.dlll
I have a 3 yr old HP dv9205 17" monitor.... It will not start up... Begins powering up...blue...
(More)
I have a 3 yr old HP dv9205 17" monitor.... It will not start up... Begins powering up...blue lights all come on for about 20-25 seconds..nothing on screen... then shuts down...and begins cycle again....will do so until I interupt the power Is this a mother board...or hard drive problem? HELP!! Matt
I'm trying to use ultrasurf at work, which has a hardcore block system, it keeps failing to connect...
(More)
I'm trying to use ultrasurf at work, which has a hardcore block system, it keeps failing to connect to server...any ideas for me?
