Question about Whirlpool GEW9250P Electric Dryer
Dryer takes longer
The dryer seems to be taking longer than it use to, we replaced the vent to the outside and shortened the line, there was no build up on the outside. the lint trap had some but we cleaned it out but it still takes long to dry .\ , any ideas
  • 283 Answers
You need four things,each in the right amount to effectively dry clothes: Heat, Airflow, Tumbling and Time. The first two account for probably 90% of dryer problems. It looks like you almost ruled out #2 but this design likes to build lint up in the filter housing below the filter. Shine a strong light down into the slot where the filter goes. Pick out any clumps with a refrigerator coil brush and a vacuum. To rule out not enough airflow due to long vent etc. run one load through with the vent totally disconnected and see if it makes a difference. Otherwise we'll asssume the drum tumbles and that you're setting it for enough time. Check the temperature is left. You can get a rough idea of the drum temp by using a meat thermometer in the exhaust duct. Normal range is between 140-200 degrees.
Posted on Jan 06, 2008
2 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: dryer takes longer
check the humidity sensor not working
Posted on Mar 09, 2008
What is c c error code on a mtag nepune dryer
don't know what that code is, you say you changed out the coils,if the flame is liting but it takes to long to dry you must have a block somewhere,either in the vent line or in the duct where the lint filter slides down into,try removing the vent line and see if that helps,also if you haven't cleaned out the dryer and vent line in more than a year most likely this will be your problem.if the vent line is long you can stick a leaf blower into it and blow it out to the outside,first make sure nothing is blocking the outside hood where it vents out,i just found this problem last week there was a birds nest in the outside hood because the flapper didn't close,cleaned it out and it was fine,all a dryer does is move air,if there's a block in the vent line or dryer from lint buildup the heat won't stay on and it will take longer and longer to dry the clothes,also there's a cycling thermostat that could be bad,it's on the top of the blower wheel housing next to the thermal fuse.hope this helps
Oct 15, 2014 | Maytag Neptune MDG9700A Gas Dryer
Dryer works fine except it does not seem to heat properly. Wondering how the element is installed and where I could find replacement heating element.
I would need a model number to look up your heating element.
I can tell you that chances are if the dryer heats, but just takes to long to get things dry the heating element is probably ok.
Poor air flow is what causes dryer to take longer then normal to dry.
You will want to check your vent for restrictions such as kinks or lint build up. Don't forget to check the outside hood as it has a flapper or even a screen that can catch lint.
If your vent is ok then you need to take the dryer apart and check for lint build up around the blower housing and fan.
Aug 02, 2011 | Dryers
It takes forever to dry clothes. A small load takes at least an hour & a half, sometimes longer.
The most common problem for a dryer to take more than one cycle to dry is restricted air flow.
1.when the dryer is running go outside and find where the venting is located, there should be a good amount of air flow.
2. if the air flow is not good look at the ducting coming from the back of the dryer and make sure it is not kinked or pushed back to far.
there is usually lint build up some where along the ducting or at the end of the duct where it vents to the outside.
3. if you have access to a leaf blower,this can be used to help clear any lint build up inside the duct from the dryer to the outside venting.
move your dryer out and take the leaf blower tube and stick it in the hole and turn it on.
the vented louvers need to be removed from the ouside of the house to allow the lint and things in the duct work to be blown out.
Feb 17, 2011 | Kenmore 73952 Gas Dryer
Dryer takes longer to dry, doesn't get as hot as before
Feb 10, 2011 | Dryers
It takes forever to dry a load of clothes. Drum
Have you checked your vent for blockage? Over time, lint build-up in the vent and in the back of the dryer makes your drying time longer and longer. Unplug the dryer, pull it out and disconnect the vent. Using a flashlight and a vacuum, clean out the back of the dryer that connects to the vent and the vent itself. If you have a long vent line, you'll need to find a away to clean it out to clear any blockage. I use a hand-held plumbers snake that rolls up and pulls out as much length as needed. Then spin it around in the vent to knock off lint attached inside the vent tube walls. It may be easier to do this from the outside, but you can do it from the inside too. Check your outside vent cap for blockage and make sure the vent flap outside is not stuck closed. Also make sure when you push the dryer back into place, that you don't squish the vent tube, if it is made of plastic or foil. After reconnecting the vent, turn on the dryer. The air flow may blow out the lint you have dislodged with the snake. Clean out as necessary at the outside vent. I have a long vent line on my dryer, so I have do this annually. This has helped shorten my dry time every time I do it. Of course, cleaning out the filter regularly, does help too. The more often you clean the filter, the less lint that will build up in the vent . Hope this helps. Douglas
Jul 17, 2010 | Maytag MED5600TQ Electric Dryer
Too much lint is getting past the lint trap. How
if the filter isn't damaged then this is normal,you should take off the bottom panel and use a shop vac to blow out all the lint inside the dryer especially the motorand blow it forward and vac it up so you don't have to pull the drum to clean it,then remove the lint filter and take off the duct that the filter slides into,now go outside and make sure nothing is blocking the flapper like an animal cage that comes with some of the outside vents,if it's clear go inside and remove the vent line,if it's a long run from the dryer to the outside blow it out with a leaf blower,you should do this once a year and your clothes will always dry on time and your motor and other parts will last longer,when the lint builds up the dryer runs hotter and longer and that's what damages the dryer
Feb 06, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer taking longer to dry clothes
For a gas dryer:
Assuming the dryer is working properly and the control cycles are ok, look for things like a restricted venting system which inclides the exhaust, lint screen, etc. This would be the large pipe connected to the dryer exhaust that vents outside.
If it's an electric dryer, there could be issues with heating elements, thermostats, a control board, the timer, etc. Also check for any excessive lint build-up.
Apr 12, 2009 | Dryers
Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Jul 08, 2008 | Whirlpool ET8CHEXSQ Dryer
Dryer takes longer
Mar 09, 2008 | Dryers
Electric dryer lint
You are purchasing new dryers when the problem is your vent line. The fact that your old dryer is now working in a different home, and your new dryer still has the same problem as the old dryer, leads me to suggest that you reroute your vent line some how. Your dryer vent line is really too long. The fact that you've added two 90 degree bends also leads to the issue of lint build up problems by creating added resistnace. It's a simple theory of operation when it comes to dryers. The SHORTER and STRAIGHTER the vent line the BETTER. All vent hoses create some resistance to air flow. It is typical in longer runs that the lines build up and accumulation of fine lint over a period time which adds weight to the line. This can cause the line to sag and restrict lint even more. Any bend in the line (especially 90 degree bends) also create points of resistance where lint tends to build up. This eventually leads to clogs, longer dry times, dryer overheating and eventual failure of the appliance. Purchasing higher end models does not necessarily equate to better performance. Many of your low end Kenmore, Maytag and Whirlpool models are great dryers and last years with proper care and maintenance. Even though you don't have this configuration, I thought I might add that it's also a bad idea to have vent lines that run vertical (such as in an attic). Dryer exhaust has moisture content from the clothes. When the lint mixes with this moisture it becomes more dense. If you have a vent line that runs vertical, this line will eventually settle at the lowest point of the vent line (which is usually right where it enters the wall). Reroute your vent line and shorten it and I bet your problems will go away. It's cheaper to spend the money on some semi-rigid vent hose than several hundreds on another appliance that will probably give you the same results. I hope this helps you,
Jan 16, 2008 | Dryers
Whirlpool GEW9250P Electric Dryer Logo
168 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
