Philips 55PW9363 55 in. Rear Projection HDTV-Ready Television
Problem for Philips 55PW9363 55 in. Rear Projection HDTV-Ready...
I am unable to adjust the multipoint red
By loree_l_well on Nov 10, 2009
I am unable to adjust the multipoint red convergence left and right, but can go up and down. Is it a remote problem or the tv?
Best Solution
posted on Nov 10, 2009
Very Helpful)
SD Tech
Rank: Guru  Philips Televisions & Videos  Expert
Rating: 97%, 908 votes
NO, if red or blue will not adjust you need to replace both of the STK-392-120 convergence chips that this model uses.
There is a reason this happens.
The chips are black in color--2 1/2 inches wide X 1 1/2 inches tall with 18 pins each--they are mounted on two metal heat sinks on the board on the far left as you look from the back.
The back of each chip is metal and white grease to transfer heat quickly is applied to the back of each.
After some years the grease dries out and one of the chips overheats and fails.
There are if you locate the chips about a dozen light green resistors in front of the one towards the front of the set and to the left of it--they are all protection parts--all are 6.8 ohms. If any are discolored in the middle they need to be replaced along with both chips. They are easy to check--like checking a fuse--any that have NO reading across are gone.
Usually just both chips and a pair of the resistors need to be replaced and the set adjusted--I have done hundreds of these sets with this kind of problem
Considering that you can buy a pair of the chips on Ebay for less than 13 dollars plus shipping--if you or someone you know can do the repair--you can save the set and a lot of money--most shops get 300 or more for this kind of repair.
If you or someone you know can do it I will tell you what you need, how to get at the parts, and the best place to buy them.
The first step would be to look at the protection resistors to see or test if any are bad--do it with the set unplugged.
If you need help or advice, let me know--I am here to help people.
If this information has helped you, rate this solution as I DO THIS HERE FOR FREE.
SD TECH
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
Not Helpful)
vljenterp81
Rank: Wiz  Televisions & Videos  Expert
Rating: 82%, 22 votes
it sounds like a remote problem check the batteries in it and see if they have full voltage in them.
Was this helpful?
Yes
No
Popular Solutions for Philips 55PW9363 55 in. Rear
Questions and Unsolved Problems for Philips 55PW9363 55 in. Rear
Do you recommend Philips 55PW9363 55 in. Rear Projection HDTV-Ready Television?
Answer
Answer
Problems with Philips 51PW9363 51 in. Rear Projection HDTV-Ready. White colors glow on the TV.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 55PW9363 55 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
