Door out of alignment. I can only find two screws at the top hinge and I do not know how to align the door with only these two screws. What is the procedure.
The bushings in the hinges are most likely worn out.If the screws,or the slots in the hinge will allow for adjustment,loosen the screws and move the door to desired level,and re tighten the screws.Removing the screws,and removing the door from the hinge,you can set washers on the bottom hinge to raise it up,is what most people do.When you remove the top hinge,with help,remove the door by lifting it straight up.Place two,or three washers on the stud,on the bottom hinge,the replace the door,on the hinge,and the top hinge,back in place.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Frigidaire FRS3R5EMB Side by
where would I get an inline pressure regulator for my refrigerator. My refrigerator model...
(More)
where would I get an inline pressure regulator for my refrigerator. My refrigerator model #FRS23K5CQ2 started leaking out of my icemaker cartridge compartment into my front door shelf. one of the solutions said that if your water pressure is too high for the shut off valve in the icemaker. I noticed that the city was going around to all the houses and did something to our water lines and two days later my refrigerator was leaking so i think that I have the same problem. I stopped at Sears where I bought my appliance but they didn't have that part so I'm not sure where I can get it. I want to install in between the city pressure and the icemaker only. Thank-you, Jayne
Food put into the fridge freezer appears freezer burn't after only a few days. Everyting else is...
(More)
Food put into the fridge freezer appears freezer burn't after only a few days. Everyting else is fine. Whats the problem?
We have a crown series refrigerator and under the crisper pan at the very bottom of our refrigerator...
(More)
We have a crown series refrigerator and under the crisper pan at the very bottom of our refrigerator side there is an accumulation of water and ice. We have raised the temperature on this (the nonfreezer side) but we still have ice and we still have an accumulation of water so much so that we need to sop it up with a sponge about every week and if we wait too long it overflows onto the floor. Our fridge is about 7 years old and we have recently changed the filter hoping that would help but is has not.
