Question about Coby MP-C7085 MP3 Player
Can not down load videos
Try every thing
  • 26 Answers
The videos need to be in .MTV format. Only .MTV converter that seams to work. After it is converted you can put it in any folder. To play the video, you have to hold down the menu button for a few seconds until it displays the function menu. Then choose the video function.
Try to find mtv converter at http://www.mtvconverter.com
Posted on Dec 10, 2008
  • 68 Answers
Put your player in MSC USB mode, convert your videos in MTV format with the video converter, then drag and drop them in the MOVIE.DIR file of you player.
Posted on Jan 07, 2008
80010514 ps3 error
Try this hold power button down until unit shuts off then hold down power button again watch the green led it will blink 2 times on the 2nd blink let go. it will come up with a menu to do things try #3 ..
Also that error looks like the sign on error when your network settings are not in the system.
Apr 18, 2014 | Sony Video Game Consoles & Games
Three beeps at interval no thing on monitor. what can i do? ihad just loaded a new os and was working fine.i shut down and change memory stick.turn back on and hear these beeps.re-install origin memory...
Beeps are mainly caused by bad, dusty memory module or the port it is connected to. However, since you have tried changing it with a working one and i suppose you already clean it that's fine. One more hardware which causes beeps is the video card. If you have a video card installed, it may be moved when you change the memory module. I suggest you try to reseat the video card as well..
Hope that works
Feb 13, 2011 | Asrock K7S41GX Motherboard
HP Pavilion Elite M9040N will not finish loading windows after green bar just goes to blank screen. tryed to restore to factory spects bot same thing.
hello
possible video drivers are corrupt.Try a reboot and hold f8 key down.
When prompted choose start in safe mode,then reboot again as usual.
Aug 30, 2010 | HP Pavilion M9040N Elite Desktop PC
U tube videos play slow and sound plays first then visual starts jerkly to play. I have added the max extra ram
That may be your network connection or your cpu load. I'm going to say your cpu.
On a older laptop like that the cpu can run out of power when playing video's. The extra ram should have made some improvement for other things and helped a bit with the video.
First we want to do ctrl-alt delete to bring up your task manager. Look at the CPU usage number. With nothing else running it should be 0-1% maybe as high as 2% then drop to zero. Anything higher than that and you have too much running. If you click on the top of the colom where it says CPU it will sort by cpu use. You may have to scroll up or down to get to the big numbers, most should show zero. The big number should be system idle at say 95%+ followed the task manger taking up most of the rest. Usually what happens on older machines is they don;t have the extra horsepower to cope with all the new programs demands so they bog down. So what you can do to help this is to stop anything that you don't need from running. These are things like speed loaders or auto updates. For example if you run office or use adobe products you don;t need to have it load a speed loader (which doesn;t really seem to speed up anything) everytime. If you look at what is in the start-all programs-startup these are things that are loaded at startup. Removing things from here will stop them from auto starting. If you don;t know what these things are chances are you never use them. If you drag them out of the startup to the previous menu you can still manually start them.
Next make sure you don;t have any messengers running. Most seem to set themselves up to load with windows. Some like MSN are bad for loading the cpu. So under the options for those uncheck load at windows startup.
And last you may be running a antivirus program. These are also pretty hard on the cpu. Usually there is an icon near the clock. If you right click on it there is usually a menu selection that will turn off (or back on) the antivirus program . It should restart when you reboot.
You may also want to see if there are any other programs or managers such as print mamagers or other programs that want to load at boot. Either disable these from auto starting or exit from them before trying to watch.
Those are the easy things to try to speed things up. I have a old compaq I use for watching videos from time to time that is about the same as yours. These are the tricks I use to watch youtube vids. When I don;t turn them off etc I had the same symptoms.
May 05, 2010 | Panasonic Toughbook CF-27 Notebook
Im running XP home n I can down load my videos but cant play them
You will be needing codecs to run your system fine.
K-lite codec pack helps install certain codec formats which your system is not able to recognise.
Click on the link below to download and install the codec pack.
http://www.free-codecs.com/K_lite_codec_pack_download.htm
Choose the full latest version in the list available.
If this does not work then kindly comment.
Jul 12, 2009 | JVC Everio GZ-MG30 Camcorder
How do I get my JVC MiniDV GR250AA to down load onto computer have just installed software and a firewire card etc says every thing is working but will not capture video. any Ideas?
Found a Forum with the same question and it had a lot of answers for the same problem. Had to go to the MS website and down load a security update for xp sp2 to reset the iEEE ports so that the w/movie maker would capture the video and audio.
Jun 28, 2008 | JVC Cameras
Will not turn on
mines done the same thing i tried to unplug it then plug it and it still won't work... it's f**ked
Feb 11, 2008 | Nintendo Wii Console
Down loading footage on to a computer
Try using Windows Movie Maker to download the footage.
Oct 17, 2007 | Sharp VL-Z500H Mini DV Digital Camcorder
Coby MP-C7085 MP3 Player Logo
104 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
