Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
D Link 604 will not connect to internet
Is there so magic to using the D Link 604 router? Did the setup three times still no connection.
  • Anonymous Jan 14, 2008
    I have the d-link DI-604. I follow steps 1, 2, 3 in the quick installation guide as written but when I get to the open web browser the system fails to find the internet. I have tried repeated but no success. Do I have a lemon?
  • wzm_jiv Sep 11, 2008
    D-Link DI-604 4-Port Cable/DSL Router Broadband ) Bridge
  • 101 Answers
Hi Goldy,
The 604 should setup easily. Make sure you have it set to automatically get IP if you are using Cable, and for PPPOE if you are using DSL.
Once you have it setup. Shut down everything. Plug in the modem, wait 2 min. This allows the modem to get the info it needs from your ISP. Then bootup the 604. Wait 2 min, for it to get the info it needs from the modem, then boot up your computers.
Got to start>run and type in CMD. In the black box that opens, type in IPCONFIG. Your IP listed should be 192.168.x.x. THe X's can be any number from 1 to 253. If the IP is, you are not getting data from the 604. Check your firewalls, expecially if you are using a third party one, like Norton.
Posted on Jan 07, 2008
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
Sep 15, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
DI-604 url will not take me to the setup for the rout
Sounds like they both are getting the same IP address. Remove the x-box and see if you can log into the router. You may have to power cycle it. Once on, log into the router and make sure that DHCP is configured. Then attach the x-box and it should get a seperate IP address
Jun 22, 2009 | D-Link DI-604 - 4-Port Broadband Router [...
are any lights going off or flashing on mdm ? then call isp . . when was the last time you pwr cyc mdm AND router if it has been awhile try that turn both off for for 3 to 5 min turn mdm on first wait for dsl light wait 2 min turn router on wait 2 min try again if still have problems connect direct to mdm and if still doing it it isn't the router it is the internet connection or mdm
Apr 07, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Modem and d link
Hello there,
Your internet connection should be setup properly in order for the router to give connectivity to both your computer.
You must contact your ISP and ask them for the IP's and put it in the router.
Apr 05, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Cant share internet using a router
Hi There, what model of dlink router do you have?
Also, Or just check the ports you have in your router, the internet should be connected to the WAN port and the switch and/or computers to the LAN port(s).
If the router is new by default you should be able to access internet by plug everything the way I told you.
Also, by default the router ip address should be, type that into your web browser address bar, then you will have access to the router admin web page were you can see the status page, there will tell you if you have or not access to Internet really. Maybe the problem is that the router have no access internet access at all.
Mar 12, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Switched internet service providers now the router doesn't work
You might want to check the routers settings to make sure that it is not configured to use PPOE connection which is for DSl and the Broadband connection. You can find the routers address by searching google. Linksys uses You can always try resetting the router by pushing the reset button usually found by the power plug in the back.
Feb 19, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Dlink Broadband Router Dl-604
You can connect many computers to a network with switches, (or hubs if you want an even cheaper option) but in order to connect to the internet there will need to be a router (or modem) to connect to your ISP.
anything else?
May 09, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
How to connect di-604
i connected with DI 604 since then i can not view the photos on my friendster account
D-link di-604
I have no success disabling the DHCP server. For me at lease, this will not work
Apr 02, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
Open Questions:
See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
539 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
