Refrigerators
Problem for Refrigerators
Generic problem for all Refrigerators
My refrigertors stop working
By nikky69hit1 on Nov 10, 2009
my refrigertors stop working
Comments:
Nov 10, 2009
- the refridgertor was working ok and it stop working.when I turn the nob to zero and to it started up again then after a few hours it die again.Now it just wont turn on
Solution #1
posted on Nov 10, 2009
Helpful)
roniecon
Rank: Guru
Rating: 88%, 670 votes
First thing to do,is,see if the compressor is running,it should be humming,and warm to the touch.There should be a fan running under the unit,cooling the condenser.And the fan in the freezer unit should be running.If none of these are running,check to see if there is current in the wall plug,maybe plug it up to a known hot,receptacle.If the fan in the freezer is working,or the condenser fan,check the thermostat to see if it is working.If it is,take a 120 volt,volt meter,and check the voltage going in the compressor,if it is getting voltage,and is real hot to touch,then it is bad,the compressor,or if it s not running,then it is bad.If the compressor is running,and the large line off the compressor is cold,or near it,then it may be just low on freon.So many things to check here.
Comments:
Nov 10, 2009
- Look under the unit,and see if the condenser fan will turn,if you can get it back on,clean the condenser real good,if it is full of dirt and debris,so the cooling fan,can clean it.Now you may have to remove the thermostat and cross it out to get the compressor back on,the thermostat may be all that is wrong with it,if the compressor stays on,and the fridge cools,then replace the thermostat with a new one.It will take all night for the unit to cool down.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you I will try it " - nikky69hit1
Popular Solutions for Refrigerators
Questions and Unsolved Problems for Refrigerators
Answer
I am thinking of buying a used 2005 GE side by side fridge model GSS25XSRCSS. Any experience good... (More)
Answer
the samsung four door quattro refrigerator
Answer
hotpoint rfa17 green light gone black and freezer on defrost ?? what is up
Answer
Westinghouse RJ523V-R fridge door hanging on an angle. Now it doesn't seal. Is there a way to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
