Question about Broan-NuTone Allure II QS230SS Kitchen Hood
Filter light on Problem
My filter light stay on at all time, I cleaned the filters and disconnected the fan to cancel the "problem"  , the light went off but as soon as I started the fan again the light came back on.
Help please with this problem.
Pierre
  • 38 Answers
ControlBoard. Part # R111638. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Posted on May 14, 2008
Took filter out to clean pressed contol switches to cancel red cleaning light but think I pressed wrong switches on control continually flashing when switced on and fan not working
You have entered a programming mode. BTW, the light is a time activated thing. There is no sensor for blocked filters. It is just there to remind people that don't bother clean them regularly. Try holding the on / off button in for 5 seconds. With out knowing what you actually did, it is a bit of a trial.
Feb 10, 2014 | Miele DA 289-4 Kitchen Hood
Not much heat and clean filter light comes on when filter is clean
This sounds like air flow restriction. Test by disconnecting the hose at the back of the unit, form an opinion of air flow and see if filter light stays off.
If ithe filter light stays off while running with hose disconnected, hook the hose back up and investigate the restriction in the hose, next most likely place to look is at the discharge opening at the exit of the building.
If the filter light is still on, you likely have a restriction or lint build up inside the unit, you have to unplug, open the unit and find the restriction.
Mar 06, 2011 | Siemens Dryers
My TLP-S10 lamp will not stay on after a couple of moments.
Is the fan working. Check fan. Very likely the device overheated. If fan is working the air filter might need to be cleaned. See you manual how to clean filter and reset the filter cleaning counter so that the device can work properly again.
Feb 17, 2011 | Toshiba TLP-S10 Multimedia Projector
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Message comes up telling me it's time to clean the filter then my tv turns off automatically. It does this about 6 times every morning before staying on. How do I clean the filter and more importantly how...
Read ur user manual,find out where ur fan is the filter is nearby,must clean filter,keep adnoring this,ur projection picture bulb,work harder have less life span.Might in times even kill ur light engine projection.That will cost alot of money to replaced,and have to have technical skill to replaced this.
Apr 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Error code f21, and the door stays locked
Error Code F21 = LONG DRAIN
Most probable cause is a foreign object blocking the filter. Remove the lower front panel. The filter is located in between the pump and tub. remove the filter and clean out foreign material (socks, coins, nails ect..) and reinstall If not check the following items
is running.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Changed water filter red light stays on
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
Clean Filter Red light
I cleaned the filters as well earlier and the red filter light still blincked to clean the filters. Then I pushed the power button for about 10 seconds continously and then turned it on and the light turned off.
May 22, 2008 | Brookstone Pure-Ion UV Air Purifier
About 52 in zenith tv fan
If the air filter needs cleaning The fan will stay on for an extended time to cool the light engine. Try cleaning the air filter that should solve your problem
Mar 11, 2008 | Televison & Video
Broan-NuTone Allure II QS230SS Kitchen Hood Logo
724 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Marvin
Marvin
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
