When the Xbox 360 overheats it causes the lead free solder to crack, the more that crack the worse the
machine will get. So eventually I suspect your machine will die completely and show either 3rrod or e74.
To remedy this you need to strip the console down and replace what's called the X-Clamps, at the same
time replace the heat-sink paste and then you need to re-heat the whole board. We use a special IR over
which re-bakes everything and re-seats the solder properly, a lot of people use a heat-gun but you have
to be very careful.
I just set up the console but can't get a clear image. You can see shadows of what should be there....
(More)
I just set up the console but can't get a clear image. You can see shadows of what should be there. The system is not set up on an HDtv it is on a normal tv. Does this have something to do with it?
xbox does not show up on my computer screen when I plug it into the fios modem. the box is new and...
(More)
xbox does not show up on my computer screen when I plug it into the fios modem. the box is new and not registered yet
i got a xbox game from america and it want play in my xbox says the region code for this box is not...
(More)
i got a xbox game from america and it want play in my xbox says the region code for this box is not compatible any suggestions how to get round it
