Question about Office Depot Ativa DQ60M Shredder
No power to SPL-1506X
I have an SPL-1506X, and the power light doesn't come on when I plug it in.  When you switch it to auto or reverse, it doesn't do anything. I've only had it about 6 months, and it gets pretty moderate usage.
  • 3 more comments
  • PaulieS Jan 21, 2008
    I have the same problem. The unit comes with a one-year warranty (mine's older...) so I would get the receipt and return it to the retailer.
    If anyone else knows if there is an internal circuit breaker or fuse I can replace I would welcome the advice.
  • Robert Robert Jan 30, 2008
    I'm on my third spl-1506x shredder, and now have the same old problem with no power to unit. I seriously believe that there is an inherant design flaw with the electrical control of these units, and Staples should send out some kind of a fix for it. If the problem is due to periods of prolonged usage, the overheat lite should come on -- but this has never happened with any of the units. Where do we go from here?
  • Anonymous Jan 31, 2008
    I'm having the same problem with a unit I purchased at office depot.I barely used this thing.
  • dlforbes Feb 16, 2008
    I have the SPL-1506X shredder and it too stopped working. No power light, nothing. I took it apart and found a 7amp fuse blown on the circuit board. Will go to Radio Shack and hope they have the right size fuse. Good luck to you as well.
    DLForbes
  • Anonymous May 09, 2008
    On my SPL-1506X, I am able to use my Reverse button, but I get no power on my Automatic button. Staples says that it appears to be a problem with the gears on the machine and says my 1-year warranty has elapsed. Could it also be a fuse problem?
    New Friend:
I had the same problem-one day the shredder worked, the next day no power. We checked the fuse and it was ok. There is a safety switch that has to engage with a plastic tab on the bin. For some reason it was no longer engaging. We put a piece of cardboard into the slot and now it works fine.
Posted on Jan 18, 2010
  • theresa johns Mar 23, 2013
    Thank you so much was fixing to trash the shredder and now im glad i didnt .....thats all that was wrong, put a piece of cardboard in slot now works fine.
  • marlene jazak
    marlene jazak Jul 29, 2017
    where is the slot
If the fuse keeps blowing remove the Rectifier and replace. Just repaired my shredder for under $5.
The new part can be found at any electronics website (someone small, like radioshack will not carry the size needed)
the part number RS807 (8Amp Bridge Rectifier)
Josh
Posted on Oct 03, 2008
There is a fuse on the circuit board, you should replace. If you are not getting any power.
Posted on Feb 11, 2008
  • mrodrigue934 Apr 12, 2011
    Where is the fuse piece located?
If you continue to blow fuses and are confident with soldering you can replace the Bridge Rectifier. It is located near the fuse and looks like a black rectangular box.
Remove the old one and solder in a new one.
Part number is RS807 (radioshack will not carry this part, try digikey or mouser)
Josh
6ya staff
SOURCE:
Replacement gears spl-1506x
unless that shredder is heavy duty office and very expensive , it will be cheaper and easier to junk it and get a new one
mostly parts are non existent for shredders
Sep 23, 2018 | Staples Office Equipment & Supplies
Bin full light stays on and stops shredding and bin is not full
Piece of shredded plastic may be sticking on the "full" sensor, or switch
Mar 05, 2018 | The Office Equipment & Supplies
I have a Staples Shredder model SPL-TXC6A (serial 0809026807), which I have been using a lot lately. The auto and reverse buttons will not function, & neither will the forward button.
If you have used it a lot, it may have tripped the thermal fuse. Normally, these reset themselves. One thing to make sure of,, is that the safety switch under the machine is firmly on the pin in the basket under it.
This is a light duty shredder, you can only use it for two minutes!
6-sheet, light-duty, up to 25 uses/day
Runs 2 min on / 4 min off
http://www.snoopdeal.com/bargain/43085/Staples-SPL-TXC6A
Nov 21, 2016 | Office Equipment & Supplies
Staples spl txc10a
First determine if there's power to the unit. Plug something else into the receptacle and verify if it's working.
If OK, plug the shredder into the outlet and turn to it's "auto" position. You should see a red or green LED light up, indicating that it's powered up and ready.
If you get a light and it still doesn't work, it's probably the switch that senses the paper entering the slot is stuck closed (adhesive from labels and the like, or paper dust can cause this. Personally I would just buy a new one (not worth the cost of repairing).
If no light, check to see that it's sitting on the waste container properly. This units have a safety switch and it it's not seated properly, you get nothing, no light, no motor, no shred.
Dec 26, 2017 | Office Equipment & Supplies
Spl-1506x shredder only runs in reverse
Daniel:
Unplug the shredder... Take the top off and turn it upside down. Use a screwdriver to take the lower cowling off and look at the motor. If the mounting area where the motor sits looks melted at all, the machine is toast. If the motor mounting area looks good, look at the slot where the paper is inserted... there should be a sensor (that "sees" the paper when you insert it) at the paper slot. Check to see that the sensor isn't damaged.
Nov 11, 2012 | Staples SPL1506X (CrossCut) Shredder
Automatic switch does not shut off after shredding on Staples model SPL-1506X shredder.
These shredders have a "paper in" sensor. This is either optical or mechanical.
Sounds like the sensor is blocked and therefore "thinks" there is still more paper left, and this is why it keeps going.
Before you do anything UNPLUG THE SHREDDER.
The sensor is located about in the middle and at the level of the blades.
If it's mechanical, you should see a little finger, else it is electronic.
Shine a light in the area and you should be able to spot where the blockage is.
A shot with compressed ais usually gets rid of the offending particles.
After you're finished working on it, set it back securely on the basket and plug it in.
Feb 13, 2011 | Staples SPL1506X (CrossCut) Shredder
The blades are stuck in reverse
I have the exact same problem. In fact, my SPL-1506X is sitting disassembled on the kitchen table as I write this. There is a PC Board inside the unit with a relay that directs the motor to run in forward or reverse. My relay is fused in the reverse position. I know this because the relay's casing is clear polycarbonate. If that relay can be replaced, the SPL-1506X will be fixed, I'm convinced. Unfortunately, the relay is made in China. So much for quality! I located the part no. on the web: Sanyou SME-2110DP a DPDT relay. If you can find it(which I can't), you're in luck. Myself, I'm going to trash the unit.
Jan 14, 2009 | Office Depot Ativa DQ60M Shredder
SPL 1506X Shredder
Have you looked for hidden staples in the machine. Sometimes they can be hard to spot.
Aug 01, 2008 | Office Depot Ativa DQ60M Shredder
Shredder problem
Call us at Fellowes Customer Service 1-800-945-4545 On Monday between 7am and 7pm Central Standard Time
Feb 23, 2008 | Fellowes DM15C Shredder
Office Depot Ativa  DQ60M Shredder Logo
4,133 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Jim Keysor
Anthony Karuku
quennie732
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
