Question about Toshiba Satellite A65-S126 Notebook
Toshiba Satellite A60 powers up then off after 2 seconds
I have a Toshiba Satellite A60 laptop and the other night I was attempting to do something on battery power and it shut down (went into powersave mode) before I was done. Three days later, I attempted to start it up by using a wall outlet and it powered up and clicked off after about 2 seconds. No BIOS showed, the screen stayed black. I pulled the battery and tried using only AC and it did the same thing. I left it overnight to see if the battery would charge and it did (so I don't think it's the power supply), then tried it and the problem persisted. It was working fine before (with the exception of not coming out of standby - you had to shut down and restart if it went into standby). Otherwise, I have had no major problems. Additionally, it is about 3 - 4 years old. I could really use some help as I am not ready to pay out for a new one. Thanks.
Ireceived a toshibaLaptopA65 S126 that willk not power up. The battery and charger is fine. When I turn on the power, the fan and hard drive starts to power up and then after 3 seconds, it shuts off. The power and battery light stays green but it will not go. Any solutions?
  • 3 more comments
  • Anonymous Jan 06, 2008
    I have the same problem with my Satellite M45 S265 which is also more than 3 years old.... my led lite goes on when i plug it also and charges the battery fine..
    Well i did some diagnostic on it.. and think it mite be a bad motherboard.. b/c i removed the RAM, HDD, and CPU to see if it would power up (not boot up) and it still does the same power on and after 4-5 seconds it just turn off with the AC and Battery lite still on...
    Well I still want other suggestion b/c I dont' want to spend about 3 hundrend for another motherboard or buy another one yet.. (dont got the budget for it)... So if anyone out there can help us.. that would be great..
    Thanks for your help!!
  • Mark F K Jan 07, 2008
    The cooling fan and hard drive do come on. It just shuts off 3 seconds after you turn it on
    It really does not stay on enough to see if the dvd comes on but you can hear the fan and hard drive start and then shuts off Thanks
    I removed the ram and tried to start it with only the onboard ram and the same thing, nothing. I think I will take it back to the person I got it from since once I take it apart, it would be mine. I appreciate all your help, and I was trying to see if there was an easy fix, but I guess not. Any ideas on a good used laptop? sincerely, Mark
    Thanks for your help Jimbo,I appreciate it
    Problem Solver:
  • 5 Answers
It does come on.. even the HDD and the DVD drive.. checking for a disc etc. etc. then it just shut off
Posted on Jan 07, 2008
  • Anonymous Jan 07, 2008
    Thanks jimbo6... I really appreciate your help.. and thanks for the links to the sites..
  • lionwes Dec 22, 2010
    I have exactly the same problem A65-S126 model. It was working fine, then went to sleep and can not wake up since. Have removed the hd, ram, wireles card, modem... Once I was able to boot it to Desktop, but it died to blue screen shortly sugesting overheating issue. I plan to open it up to check for loose heatsink, bad fans, etc... Will update then.
  • 89 Answers
Mark F K, truong808, does the cooling fan(s) blow or come on? If not, the system will sense tha ti is overheating and will shut down to prevent further damage. Also, a thermal sensor may be failing on the Mobo and thus keep the fan from initiating. The cheapest fix is to replace the fan. Worst case scenario is another Mobo may be the fix.
6ya staff
SOURCE:
My Toshiba wont turn on. I tried holding the power
Hi there, Your ac adapter is damaged & that's why power does not transfer in your notebook. The capacitor of adapter is burned & that's why the noise started. Thanks & waiting for your feedback.
Feb 19, 2010 | Toshiba Satellite A60 Notebook
My Toshiba Equium laptop won't just turn on. When I press the power button it blinks for a few seconds and then turn off.
Is the power plug plugged in. Make sure its plugged in, and leave it in for 2 hrs and then try and power on.
If you need more help just post.
Feb 07, 2010 | Toshiba Satellite A60 Notebook
Satellite pro A60 powers on then immediately turns off. this is following an attempted bios update
It sounds like you have 'bricked' your laptop, chances are you would have to have it sent off for repair. do you see the POST screen any more before it powers off?
Oct 29, 2009 | Toshiba Satellite A60 Notebook
Toshiba Satellite A60 wont power up
It looks like some divece in your laptop dont pass POST test. Tech support from Toshiba required
Sep 23, 2009 | Toshiba Satellite A60 Notebook
Satellite A60 turns off 2 sec after turning on; periodically
Sound's like your connection to the A/C connector main's is going, inside the Pc this is.
it is a Common problem on laptops,
Needs stripping out soldering, and re-build,
$200/250 ball park figure.
Regards.
Apr 15, 2009 | Toshiba Satellite A60 Notebook
One long beep on startup, then switches off
i can if you didn't hook something back up... be that as it may... remove the memory... then plug the memory back in... power it up and see how it goes.
Feb 24, 2009 | Toshiba Satellite A60 Notebook
Toshiba satellite pro a60 power problem
did u install already all the drivers for the A60???
then, update / flash the bios... http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1213736&rpn=PSA60U&modelFilter=A60-S1072&selCategory=3&selFamily=1073768663&selModel=1213736|PSA60U
Dec 30, 2008 | Toshiba Satellite A60 Notebook
DVD drive not playing DVD's, but is playing CD's
I had something similar to this happen to my desktop. I read somewhere that are are 2 laser in the drive. One to read dvds and other to read cds. Your dvd laser may be fried.
Jun 27, 2008 | Toshiba Satellite A60 Notebook
Did u tried in external monitor??If not so do it?It seems that a problem is VGA!
Let me know if u got help!!!
Dec 07, 2007 | Toshiba Satellite A60 Notebook
Toshiba satellite A60 no boot
We can only assume that because the cd drive operates then the motherboard is operating in part, although, the southbridge chip may be damaged, as the northbridge works memory etc. Maybe it is that the processor is fried as there is no fan and the system then shuts down. Toshiba are probably half way there with the answer, unless; they investigated further and decided it was not the processor but the motherboard.
Jan 02, 2007 | Toshiba Satellite A60 Notebook
Toshiba Satellite A65-S126 Notebook Logo
487 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
