Related Tags:
This problem should be removed because:
Problem with Jet AFS-1000B Air Purifier
DOESN'T RUN ANYMORE
UNIT IS 3 YRS OLD, NOT USED ALOT. IT WON'T START UP, I THINK I'VE CHECKED EVERYTHING: THE FUSE IS GOOD, THE UNIT HAS POWER ALL THE WAY THROUGH CIRCUIT BOARD, ALL CONTACTS LOOK GOOD, POWER IS SENT TO MOTOR WHEN POWER BUTTON IS HELD ON BUT IT WON'T STAY ON. THE MOTOR IS FREE BUT IT WON'T LIGHT UP OR RUN.
Solutions (1)
Best Solution
Check the capacitors. There are two to look for, one on the
motor, the other on the PC controller board.
STEP ONE: Unplug the unit and
support it on a table.
STEP TWO: remove the controller board from the exhaust
side of the unit by unscrewing the screws holding the cover to the unit. Unplug
the motor wire harness by pressing down on the white retaining clip. They go
only one way, but it doesn’t hurt to note which is which.
STEP THREE: Unbolt
the ground wire from the face plate and the whole board should come out.
Unscrew the four screws holding the PC board. Look for a little foam pad that will drop out. Remember where to replace it. Screws and capacitor may have blue locktite on them.
STEP FOUR: Find the capacitor. It’s the part that looks like a tootsie roll,
black with two wires coming out one side. It’s between the CPU chip and the big
red square block. If it looks bloated, burnt or melted, you found the problem.
Replace it with a 1000 microfarad (1000 uf/ 10 volt) ten volt capacitor with a
radial lead. About $5 for the part at most electronic parts stores. Careful
desoldering the old capacitor to avoid damaging the PC board. WATCH THE
POLARITY. There is a negative and positive side. The negative side has a
chevron (<) mark and is marked on the PC board. On mine the negative side
was nearest the black micro chip and the positive side was towards the red JEFU
MPE part. Use a little bolt-tite on the screws of the PC board and some on the capacitor on the PC board to limit vibration. Reinstall the board, plug it in and give it a whirl.
If no joy, STEP FIVE: Find the motor start capacitor. It is bolted near the motor, black about
1x 2 x 4 and has two red wires coming out of it. Take a battery operated
resistance meter on a setting of R x 100 or higher. Charge the capacitor by
connection one lead of the tester to one red wire and the other lead to the
second red wire. You may have to strip the wire to make contact. Next reverse the leads and you should see the needle jump. Do
it a third time incase the first try was discharging. If no needle jumping,
replace capacitor. Couldn’t find this locally. May have to by directly from JET
Tools. L
Recommend you hard crimp wire splices if cutting off the
motor capacitor. . You can check the windings on the motor too. Check for
continuity between the white-yellow-blue-black wires of the motor harness. Any
combination should work. If not, motor shot, time for some bigger bucks nrepair.
Hope this helps.
Filter Queen Defender red light will not blink
I tried to reset the defender afte taking out the filters but the red light stays on and will not blink. Is this a circuit board problem or...
My Fresh Air Eqo Quest
My Fresh Air Eqo Quest shut off yesterday and I can't get it to go back on. I have hit the reset button, I unplugged and replugged, I...
my breeze AT unit comes on, but the fan does not
my breeze AT unit comes on, but the fan does not move. how do I repair this
my unit has been in
my unit has been in storage and I have just now cleaned it and put it back together, but it won't come one...how do I know if the fuse...
Add Your Solution
jet afs 1000b air filtration
jet afs 1000b air filtration runs hi speed romote or on off switch will not shut it off. you have to unplug unit to shut...
the remote will work the timer & fan speed but
the remote will work the timer & fan speed but wont turn it on or off.
I have a Jet AFS-1000B Air Purifier. After running
I have a Jet AFS-1000B Air Purifier. After running it for a couple of hours if I shut it off with either the remote or...
my JET Air Filtration System
my JET Air Filtration System AFS1000B is not responding to the remote control other than the ON button. I replaced the...
Related Topics
- capacitor
- power motor
- power won t stay on
- motor won t run
- out board motor
- how to wire a capacitor
- polar watch manual
- 1 SQUARE METER
- WHAT IS AFS OFF
- chevron
- parts for i joy
- how many square centimeters in...
- red cap
- step board
- i have a 6 wire capacitor to...
- af 1000
- manual pc board
- pc cutting out
- perfect square
- AFS lights
Fix-O-Meter
572
572 people viewed this problem
- 4 people found this problem to be helpful.
- 2 people are following this problem
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
Thanks for the info. I had the same problem with an AFS-1000B. Replacing the capacitor on the controller board did the trick. The unit is working perfectly.
I had the same problem, replaced the capacitor and the unit works fine. Cost me $1.00 and literally took five minutes to complete. Sure beats $90.00 for a new circuit board. Couldn't be happier. Thank you for the help!
