Question about Panasonic SC-HT920 System
Does not play multichannel audio (5.1) input through optical digital audio
I have an upscale DVD player, so that I can use the HDMI connection to display upscaled 1080p video from my DVDs to output video to my HDTV. I thought that using the player's digital output to connect it to the Panasonic SC-HT920 digital input would let me have the whole experience of HD video (on the TV) and 5.1 channel audio (through the Pana system), but I was wrong. When I select the 5.1 audio in the DVD an error mesage apear in the front panel of the home theater. If I downgrade the digital output to PCM (instead of bitstream) on the upscale DVD player, everything starts working and I can hear sound, but only stereo (2ch) this time.
Therefore it gave me the hint that it had something to do with the digital audio decoder in the home theater system.
Amazingly, I am able to decode with the SC-HT920 multichannel audio (5.1) that comes from the cable box and see movies that, for example, play on HBO with 5.1 audio.
I have tried every single combination of digital audio settings in the upscale DVD and in the home theater system and nothing made the multichannel audio from the upscale DVD player to be reproduced by the home theater system.
Now I am thinking that there may be some additional layer of protection in the upscale player digital output that prevents the audio being decoded in the SC-HT920.
I am convinced that it should be an internal software issue in the home theater system, that either cannot decode the digital signal that is being input to the unit or prevents the decoding due to some additional layer of protection that is output by the upscale DVD player digital audio output.
If anyone can help me with the solution (or work around) of this problem I will be very thankful
  • 136 Answers
Hi try this.
in the dvd player make sure you just leave it default (bitstream) but in the home theater receiver don't select 5.1 b/c that will only give you a virtual 5.1 not a true 5.1. In fact don't select any sound field at all just select dolby digital or dts depending on the source of the movie then you should be ok.
The only other problem i can see is that hdmi sends both the sound and picture to the tv. You will need to see if there's a function on the dvd player to only send the picture via hdmi and the sound via the optical out of the dvd player.
good luck
Posted on Jan 07, 2008
Connecting a sony dvp-sr500h dvd player to sanyo tv. using the red, yellow, white cables that came with the sony player get me no picture, no sound. do I need additional cables? the menu on the tv screen...
Here is the quick start guide
You seem to be using the Video & Audio connection. Start at the Player. Connect cables to YELLOW Video, RED Right Audio WHITE Left Audio Then go to TV and find the YELLOW input RED input and WHITE input. On some TV's they are separate, some combine them with the COMPONENT inputs (Component is 5 cables you will use 3 of them if you only have COMPONENT inputs)
Some TV's have an input button on the remote but no on screen selection. Try pressing the input repeatedly to access the other inputs. Lastly you will not get upscaling if you are using the 3 cable hook-up. To get upscaling use an HDMI cable to connect. Be sure to not have both types of cables plugged in at the same time HDMI by itself is best. If you reply with the modelof the sanyo TV I'll try to get you more info.
Jan 05, 2018 | Cyberhome CH-DVD 300 DVD Player
I have connected to my 2311: HDMI 1: Oppo BDP 83 HDMI 2: Denon DVD 1740 HDMI 3: Apple Mac Mini Issue: The Mac Mini works fine and I have audio and video through the receiver, but for the BD and DVD only...
You have to check the digital audio assignment of you AVR for HDMI 1 and HDMI 2. There is three options for the digital audio for HDMI 1 and HDMI 2. You can set it as optical ,coaxil, or the HDMI itself. In you receiver the assignment may be in optical input or in coaxial input for the two HDMI inputs.
1. Go to the system setup
2. Select input setup
3.Select input assignment.
4. Select all the three input ,you are using as HDMI
Apr 11, 2011 | Denon AVR-2311 Receiver
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
Dec 15, 2010 | Televison & Video
Your DVD player may have up to 3, sometimes 4 audio OUTPUTS. Labeled as "bitstream" which is a digital coaxial cable, another labeled as "optical" which is a fiber optic cable. Depending on the model there may also be as many as 2 different types of analog outputs, one is a 2 channel composite connection, or otherwise known as RCA and another is labeled as "multichannel out."
Your television will have audio inputs on the same panel your video cable is connected from the player. Connect to those from the player.
Dec 26, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
My player seems not able to upscale the signal from my antennea and DVDs
Upscaling will only occur when playing DVDs. You have to use an HDMI connection from the DVD player to the tv. For upscaling of DVD's you will also have to setup the upscaling resolution in the DVD player's setup menu. Be sure to set the resolution to one that your tv will support.
If your tv does not have a HDMI input, then you will not be able to use the upscaling feature.
Upscaling will not occur on antenna signals. This is not possible because the hardware (inside DVD player) is only meant to upscale DVD video.
Again, to upscale DVDs ONLY, you will have to have an HDMI cable going from DVD player to TV, set up your upscaling options on your DVD setup menu and have a TV that has a HDMI input and is capable of recieving the upscaled resolution you have set your DVD player to.
If you have any further question regarding this, let me know!
Oct 07, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
No Audio
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Dec 18, 2007 | Sony STR-DG510 Receiver
Panasonic SC-HT920 System Logo
527 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
