My red does not line up. I have a shadow or double picture and double lines and lettering.
Your Convergence amp ICs are bad. Heres how you fix It.
they are located on a huge heat sink inside your set. Just look for the largest aluminum heat sink inside your set. You will notice them they are large black ICs with about 16 pins on them. Just unsolder the old ones and solder in the replacements. just be sure to put some heat sink compound on the back of the new ICs where they contact the heat sink. You can get a de-soldering iron at radio shack with a rubber bulb to make the de-soldering alot easier and you will also need a low wattage soldering Iron to solder in the new ones. Just mark any wires you remove to get the convergence module out. That way you will know where the wires plug in when your finished. It will need a convergence adjustment when your finihed. Be careful not to bridge any of the pins with excess solder. Inspect the pins with a magnifying glass when your finished to make sure the solder from any adjacent pins arent touching each other.
Posted on Jan 22, 2008
Jan 06, 2011 | Akai PT5598HD 55" Rear Projection...
Dec 20, 2009 | Akai PTH5498 54" Rear Projection...
Jun 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Jan 13, 2009 | Akai PT4799HD Rear Projection Television
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Aug 09, 2008 | Akai PTH5498 54" Rear Projection...
Jul 29, 2008 | Akai PTH5498 54" Rear Projection...
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Aug 24, 2007 | Akai PT4298HD Rear Projection Television
May 03, 2007 | Akai PTH5498 54" Rear Projection...
134 people viewed this question
HAS RED AND GREEN LINES THAT DO NOT LINE UP WITH PICTURE
My tv looks blurry; blue, red etc. Writing is blurry also.
what is a heat sink? my husband is trying to fix our tv, the colors do not line up the right way. thanks.
red shadow on letters & images do not line up
top viewing section of 4 inches has gone and perfect focus does not run thoroughy to fix and line up problem. Manual alignment helps until set is turned off but doe not cure problem.
