Typewriter won't work after replaced ribbon
I have a brother ml 100 typewriter that was working till I needed to replace the ribbon. Now however, when I replaced the ribbon it won't type anything at all. My typewriter isn't that old. How do I fix this?
  • MTFalcon May 29, 2008
    The typewriter turns on but won't type anything at all.
    Champion:
  • 204 Answers
The ribbon is on wrong or now snapped down all the way. Use light pressure to snap it down.
Posted on Feb 05, 2008
How does the print head on a Brother ML-100 sense when it has reached the left hand side after a carriage return?
when the print head reaches the left side it touches a switch to cause it to inter the setup for the print wheel and ribbon mechanism
Dec 06, 2014 | Brother ML-100 Typewriter
My ink cartridge is not seated in brother ML 100 typewriter when replaced
ML 100 takes a ribbon that should snap iin place.. front toward you first then back drops down....
Oct 02, 2014 | Brother ML-100 Typewriter
My Brother ML 100 typewriter does not print because the film ribbon does not advance while typing. It keeps striking the same spot on the ribbon and therefore, no typing appears on the paper. If I remove...
I've had several of these ribbon cartridges do this. You might get lucky and get it freed up, but I rarely did. Look in the windows of the cartridge and see if the ribbon is not wound evenly...if it isn't you can try gently tapping the cartridge on a flat surface to attempt to even out the ribbon on the spool. If you are not successful, then replace the cartridge. I had mine for almost 10 years and the cartridge was always the problem. Otherwise the typewriter worked flawlessly. Good luck.
Sep 05, 2013 | Brother ML-100 Typewriter
I just replaced the typewriter ribbon my Brother ML-100 typewriter; however, it does not advance properly so typing does not appear on paper. What is the problem?
Take the ribbon off, see if it advances with the hand feed wheel if not you have a bad ribbon. Type without the ribbon and be sure the ribbon driver is turning. There may be a switch or setting for use of an overstrike ribbon,
DickyO
Aug 28, 2013 | Brother ML-100 Typewriter
Corrector isn't working
You may be puting it on wrong the dull side of the tape should face the paper.
DickyO
Sep 29, 2009 | Brother ML-100 Typewriter
How can I get printer ribbons for this Brother ML 100 typewriter? Can you give me the code #?
The Brother ML100 uses the BRT 1030. There are several supplies available like the lift off tape, the daisy wheel and of course the printing cassette.
check it out:
Brother ML100 Typewriter Supplies
Good luck and if you need anything you can always call or email.
Duane ONeil
www.FJAproducts.com
800-982-9989
bc.cbi?cbdid=423141670777502444&wdid=1041068402873934082 8 to 5 (pst) Mon-Fri
Sep 15, 2009 | Brother ML-100 Typewriter
Replacement ribbon
your office supplie store should have them. it is a common corr. tape if you look at your ribbon there is a colored knob on it ( orang, yellow or blue ) buy the same color. make sure you have a low tack corr. tape. if can't fined one we sell them 320-251-0092
Jan 29, 2009 | Brother ML-100 Typewriter
Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 17, 2008 | Brother ML-100 Typewriter
Ribbon problem
does the ribbon feed by hand? If not get a new ribbon.
DickyO
Dec 24, 2007 | Brother ML-100 Typewriter
Brother ML100 typewriter
Make sure that the correction tape is place in the guides one on each side small metal guides, remove ribbon to see, it should be behind ribbon guide (closes to you). Dry lift-off tape only(#3015)
Dec 05, 2006 | Brother ML-100 Typewriter
252 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
