Bissell 6595 Lift Off Bagless Upright Vacuum
Problem for Bissell 6595 Lift Off Bagless Upright Vacuum
I replaced the belt on my bissell model number
By jerminfestat on Nov 10, 2009
i replaced the belt on my bissell model number 3576-2, but when i put it back together, the brushes wont move...the belt tries to move, but the rubber just burns..
Solution #1
posted on Nov 10, 2009
Not Rated)
milleraba
Rank: Wiz
Rating: 83%, 460 votes
something is binding ... i dont know what ... you will have to remove all parts and reinstall again. Make sure the bearings spin on the brush when it is out ... remove all hair and string.
good luck ... im sure it is someething simple.
Was this helpful?
Yes
No
Popular Solutions for Bissell 6595 Lift Off Bagless
Questions and Unsolved Problems for Bissell 6595 Lift Off Bagless
Do you recommend Bissell 6595 Lift Off Bagless Upright Vacuum?
Answer
Answer
Our bissell no longer has power to the bottom portion of the vacuum. The lift off works just fine.
Answer
sounds like the brush is rubbing at the top of the roller area. Has been removed and cleaned... (More)
Answer
After reading a post here I, too, emailed Bissell's customer service. They sent me a refurbished... (More)
Answer
I have a bissell upright vacuum. The brushes at the base of the unit do not go around.
Answer
I have Bissell model 6595-1 Lift Off Bagless Vacuum. The connector between the Lift Off Canister and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bissell 6595 Lift Off Bagless...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
