We have no audio output. we just hooked up a new hd tv and everything worked,then one day the...
(More)
We have no audio output. we just hooked up a new hd tv and everything worked,then one day the receiver did not work. We have checked all the connections and it seems to be connected correctly. We cannot find the manual to this unit.
My old Sony GA8ES receiver is flashing 'protector' with no sound on the speakers. I checked the...
(More)
My old Sony GA8ES receiver is flashing 'protector' with no sound on the speakers. I checked the troubleshooting manual. It says to clear the short circuit first and turn it back on. Well, I did that and still does not work, 'protector' still blinking. I will open it up to check the fuse later. What if the fuse is fine, is the receiver dead? Tony
After connection made on marantz i have only low volume on my speakers Speakers is Sony 200 speakers...
(More)
After connection made on marantz i have only low volume on my speakers Speakers is Sony 200 speakers suround 5.1
presenta bajo volumen en el audio, se oye nitido pero para oirlo tengo que dar el maximo al control de vulumen. se oye mas o menos a un cuarto del volumen normal muy poca salida de audio como el 30 % del total del maximo del volumen
I was hooking my receiver up to two components (DVD player and DVD/VCR combo, and the TV out). I had...
(More)
I was hooking my receiver up to two components (DVD player and DVD/VCR combo, and the TV out). I had it working perfectly, but the overall volume was lower on all channels except DVD player. I swapped cables and then noticed the right channel wasn't working properly. The left channel is fine, but the right is highly distorted and low in volume.I tried swapping cables and inputs and disconnecting all but the one I wanted, but it stayed the same. When I swapped speakers, the problem stayed with the right channel. This occurs on every input that I try, and on both the A and B speaker outputs - always the right.Just to make sure, I put my older receiver back in and the speakers work fine on both channels.I had noticed that at one point I had shifted the cables so that instead of the output from the DVD/VCR going to left and right audio, one cable was on an audio and the other on composite video. I think this is what happened. Is there a shop manual available to pinpoint the part that is bad so I can replace it? Are parts (circuit boards or board level components) available for repair? I can solder with the best of them, but need to pinpoint the problem area. A schematic and parts list would help.
