Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher Door Leaking Steam
I have a fully integrated Bosch SHV45M03UC dishwasher that is leaking form the top right of the door. Mostly steam is leaking but looking at posts the common solutions do not apply in this circumstance.. 1) the stem vent is not blocked, will leak when empty. 2) not too much soap, will leak when empty. 3) door seal is ok Etc...
What I do notice is that the door does not seem to be shutting tightly enough. I can push on the door during a cycle and hear the cycle get noticeable quieter. Leaving me to believe that the door is just not closing tight enough.Is there an adjustment to the latch to tighten the seal the door makes when closing?
  • 2 more comments
  • sail2relax1 Jan 07, 2008
    Thanks....  I will give it a shot on the next cycle and see how it goes...
  • sail2relax1 Jan 11, 2008
    textonor's solution was it...  Worked like a charm.. Thanks
  • Gary Ulrich
    Gary Ulrich Feb 08, 2008
    I have the same problem on a new SHX43. Steam is released at top right corner.   New counter top was installed prior to first use.  Steam damaged wood counter top support.
  • Anonymous Mar 27, 2014
    Steam escaping from top of door over glass setting button, seal seems Okey does the door catch need adjusting?
    Novelist:
  • 130 Answers
Pull the seal that is on the tank 1/2 way out then close the door. This will make sure the door is tight to the seal. This happens sometimes that the seal becomes flattened. I have been using this trick on Bosch dishwashers since this series came out in 1997.
Posted on Jan 06, 2008
6ya staff
SOURCE:
Hi, I have a Maytag Mdb8959sas dishwasher that was leaking during a normal wash cycle. I pulled the dishwasher out from under the counter and saw that it appears to be leaking directly below the point...
I will assume that you have cleaned gasket around door and at washer. Quite often a build up of scale at lower gasket surfaces is all that is causing leak.
Feb 19, 2014 | Dishwashers
FRIGIDAIRE DISHWASHER LEAKING FROM TOP LEFT CORNER OF DOOR IN THE VENT AREA
Typically in this area of the dishwasher door there should not be any leaking. You might be experiencing severe steam and condensation from a cycle that has been completed. You may also go to open the door after a cycle is completed, and a little residual water will escape out of the vent that is angled downward.
Dec 21, 2012 | Frigidaire Dishwashers
Steam is leaking out the top of the dishwasher door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Dec 20, 2010 | Frigidaire 24 in. FDB421RF Built-in...
Leaking steam from sides, ruined cabinets. Is this able to be fixed?pld4555rfco
Replace the gasket in the door...
Leaking Dishwasher
heatman101
Sep 05, 2010 | Dishwashers
My maytag quiet series is leaking from the door what do i need to do to stop this leak. The flow on the bottom right move freely.......
Not sure why your enquiry landed in the Kitchen Aid dishwasher category?
It is hard to provide suggestions without having the Dishwasher Model no. I have looked at the manual for MDB7600AWW which is one of the Maytag Quiet Series category. (they must be all similar I presume)
If the water leak is minor - it could be steam condensing from the top right corner vent that is used for drying the dishes.
Other sources of water leak could be -
  • foaming of detergent - use the recommended detergent
  • unclean door liner - clean the door liner
  • dishwasher is not level - refer to installations instructions
  • door liner is damaged - replace door liner
User Manual for Model MDB7600AWW
http://shared.whirlpoolcorp.com/assets/pdfs/literature/6_919201_A.PDF
Installation Manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/6_918789_Rev_A.pdf
Technical Information (won't be much help unless you are an expert in repairs.)
http://www.servicematters.com/maytag_library/docs/16023212.pdf
good luck
Jan 01, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Bosch SHU4302 DW has a leak in the bottom left. I cleaned the gasket etc. but no luck. Slow leak drip by drip in the wash cycle. This model does not seem to have the steam vent that other Bosch models...
I've got a 4306, and while it never leaked, the bottom door gasket did seem to chemically melt over the years.
I replaced it a few months ago. I don't know that a steam vent is needed as the gasketing system never allows any steam pressure to build. And, if anything, in general, the gaskets are in worse shape now than when the dishwasher was new, so leakage due to steam pressure would have been greater when new.
Dec 18, 2009 | Bosch Dishwashers
Bosch dishwasher is leaking fresh water from water inlet assembly
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 11, 2009 | Bosch Dishwashers
Bosch dishwasher not 'steaming' plates dry
first check to make sure you don't have a air dry option.then look at the thermostat then heater.
Oct 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch SHV45M03UC dishwasher door leaking
the latching mechinisum is at fault or the door is bent.
Apr 07, 2017 | Dishwashers
Door leak
I had the same problem. On the right side of the tank in Bosch dishwashers there is a steam port. If you place a large object in the right hand edge of the tray, a pressure build up causes the leak. Put large stuff on the left and you should be good to go!
Good luck.
Dec 04, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
2,344 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
