Question about Canon PowerShot A540 Digital Camera
MEMORY CARD ERROR
I BOUGHT A 4GB MEMORY CARD FOR MY A540, WHEN I TURN ON THE CAMERA, IT SAYS "MEMORY CARD ERROR", WHATS WRONG... I JUST CANT FIGURE IT OUT, WORKS FINE WITH THE 1GB CARD...
  • 1 more comment
  • Pat55 Feb 03, 2008
    I have a 2GB card that has worked well for 6 mos. then one day it said memory card errror and will not display any photos. Sometimes it says re-format memory card. Not really sure how to do that, please advise. Not sure if I should buy new card or what. The card also does not work in my laptop anymore either.....Patrick (phelmer9@bellsouth.net)
  • Anonymous Apr 29, 2008
    Same problem as Pat but with a lot of wedding and kid pictures on the card. Any help would be appreciated.
    Paul
  • Anonymous May 12, 2008
    I put the card in the camera and said format, I have pictures in the memory card
I think A540 cannot read SD HC type. Specially the 4GB one. For the detail just visit this post.
fahmi.
Posted on May 14, 2008
    Genius:
  • 1,269 Answers
From what I can see here, the card's size is too large that your camera couldn't support or handle. Maybe your camera is just limited to 1GB or 2GB. Try plugging 2GB card and see if it detects it. I had similar prob where I bought a 4GB card and it does exactly the same thing. I consulted the vendor, he said it only supports up to 2GB thus, it's a product limitation...well I'm stuck there hehe, can't be helped at all..
If you are certain that your camera can handle 4GB card or higher, try to plug the 4GB card into a card reader and see if it detets it. If it does, try to reformat the card and try it again to your camera.
Also, 1 possible thing is that your 4GB card is password protected. Was it plugged in to any other device? If it was, try to plug it back to the same device where it was connected and disable the password.
Onother thing is the brand. Some camera is brand sensitive when it comes to cards. You may need to try different brand as well.
Hope this helps. :-)
Posted on May 05, 2008
I have a Canon PowerShot A540 Digital Camera I got a new memory card it is a sandisk SDHC 8 GB but I am getting a memory card error message.... What can I do?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Please note that your particular model camera can only use up to 2GB standard SD cards. These are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them. There are also other common causes if the above didn't help, with troubleshooting steps for this problemlisted here.
Oct 01, 2011 | Canon PowerShot A540 Digital Camera
Card locked error on screen card is unlocked and even new card gets same message
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (sorry, an A540 can only use 2GB or less standard SD cards. These are very inexpensive these days, and are available on Amazon if your local store no longer carries them). There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Aug 17, 2011 | Canon PowerShot A540 Digital Camera
I have a canon powershot a540 bought used and i cant not format the memory card
Hi Hello,if your Digital camera and memory card can't format,try to my advice, you get out your memory card to your digital camera,and you can try to reformat your memory using your computer,if the memory card can't format throught using your computer,its mean your memory is need to replace new memory card. hope its work it,thanks
Jul 28, 2011 | Canon PowerShot A540 Digital Camera
Hi, My canon PowerShot A540 camera gives an error " Card locked" Memory card error. I tried switching off the lock, but it didn't help. The card does not get recognized while inserting it in...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
You also mention recovering photos saved on the card. If you actually did take pictures with this card (assuming it's a 2GB or less standard SD card, as 4GB SDHC was not designed for your camera), you may be able to recover the photos using recovery software. See this other link.
Jun 10, 2011 | Canon PowerShot A540 Digital Camera
When I now try to use a 4gig memory card it always says the card error or card locked. I have tried card in both positions but it still says it is locked. I have tried with 3 different 4gig cards. What...
You may be restricted to using only SD cards, and many 4gb cards are actually SBHD. My sister had this problem with her camera and by putting in a new 2 gb SD card, her camera worked fine. You may need to shop online in order to find an SD card, but they're widely available online. It costs about the same for 2 2gb cards as one 4gb even though they aren't as convenient.
Nov 11, 2010 | Canon PowerShot A540 Digital Camera
A540 says "memory card error" " card locked" but 4gb card is not locked - can access card on card reader - copy on and off. a540 works with 2gb sd card no problem. please help?
The A540 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
Jan 13, 2010 | Canon PowerShot A540 Digital Camera
I just purchased a 4gb memory card for my canon powershot sd700 and it reads memory card error-card locked. I put my old 2gb card in and it works just fine. I took the 4gb back to the store and bought...
ok, first off:
make sure the card is compatible with the camera and the camera is compatible with the card (reffer to the manuals of both products).
if all checks out, contact the manufacturer of the camera first, then do the same with the card.
if everything works up to this point, but you still cant get it to work, get a new camera.
Oct 27, 2009 | Canon PowerShot SD700 IS Digital ELPH /...
Memory card error - can't format card
If it is an SDHC card your camera is too old to support it.  You need to get an older-style SD card.
Apr 26, 2009 | Canon PowerShot A420 Digital Camera
Can you use the card in another device? Can you access the card un a USB card reader? If so, it is possible that the camera cannot handle a card that big. You would need to check the manual to see that it can handle a 4Gb card.
Apr 26, 2009 | Cameras
Canon PowerShot A540 Digital Camera Logo
518 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
