Office Depot Ativa  DQ60M Shredder
Problem for Office Depot Ativa DQ60M Shredder
Ativa X1000 paper shredder that doesn't turn on
By marty431 on Nov 10, 2009
I have an Ativa X1000 paper shredder that doesn't operate. The shredder is plugged in, but the 'ready' light is not lit. Reverse / Auto: neither position does anything.
I looked underneath (inside the catch basket) at the safety switch area, but I see no switch or switch arm. I know shredders usually have some kind of safety feature, whereby the shredder does nothing unless the switch is engaged. The basket that collects the paper shreddings has a tab on it for engaging a switch.
Any thoughts on what to look for? (besides a new shredder---ha, ha!)
I've repaired a few shredders on my own...thought I'd ask while I look at this one.
thanks for a reply! -Marty
Solution #1
posted on Nov 10, 2009
Not Rated)
marty431
Rank: Apprentice
Rating: 0%, 0 votes
took the shredder section apart, cleaned out the gears of paper and a broken mount (plastic piece), and hand turned the electric motor to free it up. After assembly, the ready light works and so does the FWD/REV directions for shredding.
Was this helpful?
Yes
No
Popular Solutions for Office Depot Ativa DQ60M
Questions and Unsolved Problems for Office Depot Ativa DQ60M
Do you recommend Office Depot Ativa DQ60M Shredder?
Answer
Answer
Shredder SPL-1506x run but do not shred any paper and the overheat and overload come up any time a... (More)
Answer
The shredder will not stay on. It shut it self off while shredding.
Answer
Where can you get the 7A 125V fuse for the Ativa shredder model X1800?
Answer
i need the small circular tube that is installed in the mouth of an ativa 1000 paper shredder
Answer
the on off button does not work it wont turn on what can I do
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Office Depot Ativa DQ60M...:
Top Shredder Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Shredder Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
