The water line on HSS models , cannot be removed . They are set in the door , then liquid insulation poured into a small hole , thereby , permanently installed . You can plug an air line into the bottom of the hose , below the door , to clean out . After disconnecting the coupler .
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hotpoint HSS25GFP Side by Side
side by side ice and water in door making growling noise at ice maker had to replace water line...
(More)
side by side ice and water in door making growling noise at ice maker had to replace water line water was off but icemaker was not when i turned water back on after about 1 hour it started making intermittant growling noise
Have fridge on as high as it goes will not freeze and fridge part is not that cold. We lost power...
(More)
Have fridge on as high as it goes will not freeze and fridge part is not that cold. We lost power and now it's not working, any ideas?
The ice dispenser flap keeps opening and closing on its own. It does so without pressing the...
(More)
The ice dispenser flap keeps opening and closing on its own. It does so without pressing the dispenser. Its almost as if someone is pressing the dispense lever to get ice or water. When this happens, you can change the setting from ice to water then back to ice then you can press the dispenser and the flap will retract back to its normal closed position (momentarily). After about 5 minutes or so, it will start opening and closing again.
The ice dispenser door keeps opening and closing on its own. It does it without being touched. Its...
(More)
The ice dispenser door keeps opening and closing on its own. It does it without being touched. Its almost as if someone is pressing the dispense lever to get ice or water. You can change the setting from water to ice, then press the dispenser and it with stop momentarily. After about 10 minutes or less, it starts the same thing over again.
