RCA HD52W59 HDTV Television
RCA HDTV 52
shared by 13 users
posted by brownsugar46 on Jan 06, 2008
When switch on the light on the TV blinks 3 times but will not come on. I use the remote and it does the same thing. This started about 6 months ago. It use to take a while to come on but now it will not. It is 2 years old but is not under warrany. Can you tell me what is wrong and will it cost as much to fix as it costed? Please advise.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
12 Other Users Have The Same Problem
Posted by christieedwa on Nov 15, 2008
i have the same problem it blinks 3 times but it doesn't turn on what can i do
Posted by Guest on Nov 04, 2008
Same problem as A LOT of others!! Has RCA recalled this? I push the on button on either remote or on the TV and it flashes the green light 3 times but never turns on. What is this and what can I do.
Thanks!
Posted by cbcfactory on Oct 04, 2008
When I turn on the TV the pilot lights turn on of off three times.
Posted by wardjameson on Aug 30, 2008
light blinks three times and sometimes comes on other times it won't respond to remote to turn on for 3 minuites
Posted by Guest on Aug 20, 2008
RCA 52" DLP, purchased in "06", pictured bulb started to loose brightness. Best Buy said some lose was normal. Shortly after warranty expired, picture bulb went out, since then I have replaced it twice. It is out again, (less than six months)
Best Solution
posted on Jan 09, 2008
FixYa! (100)
ladywinn
Rank:Guru Guru
Rating: 87%, 298 votes
Right now i have 3 all different, one comes on plays 1 hour maybe shuts off ,others have convergence problems i am now looking for all information on this mostly because am finding out alot of these sets are shuting down,as soon as i find out more i will post what is wrong and what should be done for repair!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on RCA HDTV 52:
I don't want to Accept this solution
Best Solution
posted on Feb 09, 2008
FixYa! (100)
KissMyA
Rank:Apprentice Apprentice
Rating: 92%, 2 votes
1. Use 1 gallon of gasoline applied liberally to the top of the TV.
2. Light match.
3. Toss match on top of TV.
4. Watch your problem melt away ;->
Comment posted on Feb 12, 2008
Well, I just got mine back from the shop :-(
The transformer, located in the lower left corner, (facing the back of the set), was fried. Then I ended up needing to replace the board as well:-( $350.00 l8r it's working fine and has a 1 yr. warranty on the fix :-)
You could try just replacing the transformer. You might be lucky and not have fried the board yet.
Good luck all ;->
Thank You!
Best Solution
posted on Feb 08, 2008
Helpful (85)
RCAsucksbad
Rating: 85%, 2 votes
This is funny (not) I have had my TV for 2 years as well and I have the same issue. I think RCA should recall this TV and repair all the TV's that have this problem. I also think we should all get together and demand that RCA do something about this issue since it appears to be a manufacture defect or we should file a class action suit to make them pay us for our losses.
Thank You!
Best Solution
Helpful (85)
Pantera1222
Rating: 85%, 1 votes
Yes we should all get together on this TV and file complaints. This tv should have been recalled because of the major defects it had. I am pissed.
Thank You!
Best Solution
Helpful (85)
shonie
Rating: 80%, 9 votes
The picture is cut off at the top of the screen...I no longer have the remote to the televison, only the direct tv remote...how can I fix this?
Thank You!
Solution #6
posted on May 16, 2008
Thanks for Trying (70)
Guest
Rating: 0%, 0 votes
My 52in just wnt out. I think it is the transformer. It turned off and made a popping sound. It is 2years and 6mo old. I was suprised when I called RCA and they said they will fix the tv. A service guy will be out on tuesday. I told them that it was putting oyt sparks. They seamed extremly coucerned that it almost caught on fire. My be that have relized that they have a major problem with the sets. Modle is HD52W67
Thank You!
Solution #7
Guest
Rating: 0%, 0 votes
sometimes if u have the color set to high on the HD rca sets they shut off because rca sux monkey balls and horses assholes.
Thank You!
Solution #8
posted on Jun 08, 2008
Not Rated (0)
joan1953
Rating: 0%, 0 votes
I have the 52inch HD52W59 RCA projection TV. Warranty just expired, green power button flashes 5 times then pauses and continues, black screen, unemployed and can't afford 3rd warranty, guess it's not worth it anyhow. had TV 2 1/2 years.Unreal!!!!!!!
Thank You!
Can you Help with these Projection Televisions problems?
We got this tv from my brother he told me all we needed...
i can't figure out how to get my new comcast remote...
Hi Normal 0 false false false ...
how do i check if fuse is bad...
When I try to turn the t.v. on, the green light will come...
12 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jun 09, 2008
i hit the power button it blinks three times but never turn on.
Comment by cook64, posted on Jun 07, 2008
blinks three times wll not turn on
Comment by Guest, posted on Jun 07, 2008
i have had my rca 52' for about two years same model and i was hook ing cable up on the back and somethimg turned off and now it tries to three or four times then stops and wont do nothing
Comment by Guest, posted on Mar 12, 2008
PAY ALL OF THAT MONEY FOR A TV THAT WON'T COME ON AT ALL NOW!!!! RCA SHOULD RECALL AND GIVE US ALL A BETTER ONE.
Comment by people400, posted on Feb 21, 2008
we have a RCA HDTV 52 inch tv We try to turn it on the light blinks three times and the tv shuts off. We have tried to use the remote but got the same results. does anyone know why these tvs have not been recalled? What can I do to fix this problem? No one wants to work on these tvs why?
Comment by KissMyA, posted on Jan 19, 2008
My set will turn on sometimes for a few minutes, then it will shut off and the power button will blink. Most of the time it just starts blinking right away. The only thing you can do is unplug it for awhile and try again. Which is almost worthless. RCA says it is due to high line voltage. Funny it took 2 yrs. And, I have it plugged into a voltage regulator. Sounds like a built in obsolescence time frame of 2 yrs to me ;-> My 1st & last RCA TV.
Comment by bigger Joe, posted on Jan 17, 2008
When switch on the light on the TV blinks 3 times but will not come on. I use the remote and it does the same thing. I have the same problem as previous post. I have tried switching surge protectors but have the same problem. Appreciate any help.
Loading problems.
Repair Service
Find Projection TV Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
