Question about Epson Stylus C84 InkJet Printer
Printer does not print
Replaced all 4 cartrages on Epson Stylus C84 printer. Print does not print.
  • ambitious Feb 20, 2008
    I just refill the all catrages.and printer is still showinf the green and red light on.Red light is continous on. no blinking.please what i shoul do.i have done install and uninstall a lot time but failed
An ink supplier advised turning off the printer for 15 minutes, turn it on and try again. That worked once. Next time he suggested turning off printer, removing all cartridges, waiting 15 minutes, replacing cartridges. I couldn't do this without turning the printer back on and going through the replace cartridges routine. Now the nozzle check routine printed magenta and yellow only. I've run the head cleaner a number of times with no success.  Hope one of these suggestions works for you.
Posted on Feb 17, 2008
Please help me. I have a Toshiba Satellite L355D-S7825 Laptop with Vista. Can you Pleaseinstruct me on how to set up my Epson Stylus C84 printer---express Code 70445
The driver is included in your OS. If doing a wired connection, just plug the data cable into the printer. Then follow the on-screen commands (New Hardware Found Wizard). If that doesn't launch, click Start > Control Panel > Printer (under Hardware and Sound). Click Add A Printer to launch the wizard. (If you do not see this command, right click in the Printer Window and you should find it.) Select Use Existing Port, Next, Epson and Stylus C84 in manufacturer and model, Next. Then Set As Default printer if desired and Next. Then you can print a test page and Finish. (If you are using a print server or other type of networked printer, use the Add a Printer Wizard from the Printer window but choose Network.)
Ink levels available through the Printer Properties. Epson Easy Print is available for Vista here: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?cookies=no&oid=23953&infoType=Downloads&com.broadvision.session.new=Yes .
I hope this helps.
(problems with print servers can due to OS incompatibility or bad cables. Replace cables when any printer problem occurs intermittently.)
Jul 18, 2010 | Epson Stylus C84 InkJet Printer
Printer wont print out in colour The inks are full. The black ink works but not the colour inks, Epson stylus C84
Epson Requires Original Epson Ink.
Colors will not come out as they should, and then the words will print out only either top or bottom.
Good Luck....
Oct 06, 2009 | Epson Stylus C84 InkJet Printer
No printer dialogue box appearing when i ask my computer to print
If you can find the presence of the printer, right click and click properties, there must be a setting for print quality
Aug 27, 2009 | Epson Stylus C84 InkJet Printer
My epson stylus c84 printer does not print
Hi
Thanks for using FixYa. The printer won't operate properly if it's tilted. Place it on a stable and flat surface. Please do not leave your printer turned on when not in use to avoid print heads being clogged. In the instant case the ink cartridges can also leak into the printer. If the print heads are clogged then run the head cleaning and alignment utility. The print head nozzles may also need cleaning.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 24, 2009 | Epson Stylus C84 InkJet Printer
Epson c84 printer not printing after installing new ink cartidges
Hi, Linda
You may buy cartriges of different producers.
Depending on producer on them can be or be not special yellow detachable labels.
These are an yellow labels must be removed from them. Then put cartridges back. And try to clean head 4-5 times. And check nozzle test.
Good luck.
Mar 06, 2009 | Epson Stylus C84 InkJet Printer
Won't print after changing ink cartrages
After you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks,your printer will require service.
Contact an Epson technical support representative at (562) 276-4382 for further assistance.
Nov 24, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Epson c84 ink cartrages
Hello Carla, can you manually clean the heads where the ink delivers the printer. Try using the printers own program first then do a manual clean with proper cleaning solution if this will not work.
Mar 10, 2008 | Epson Stylus C84 InkJet Printer
CAN NOT PRINT LWORKS FILE TO THE EPSON STYLUS C84 PRINTER
Can you print something with a different program such a Microsoft Word? If you can then the problem is with LWORKS if not then the problem is with the printer driver. Please respond so I can help more.
Thanks for reading!
Nov 29, 2007 | Epson Stylus C84 InkJet Printer
CAN NOT PRINT LWORKS FILES IN EPSON STYLUS C84 PRINTER
Hi there HarryW - what is the "LWorks" program? Is it a Windows program - if so, you don't need a separate driver for it. All you need to ensure is that the printer is properly installed on your Toshiba as a Windows printer. If it isn't installed, just insert your Epson C84 CD and follow the instructions.
If you don't have a CD, go to
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=23953&prodoid=36033903&infoType=Downloads&platform=All
to download the driver (Printer Driver v5.4cA).
If Lworks is not a windows program, or if you have any further queries, report back to me with a new comment.
Please rate this solution if it has been helpful to you.
BIG PROBLEM
If any of the ink cartridges are needing to be replaced, the Epson C84 will not print, you will have to change the cartridge, if you lift up the printer lid the carrier will stop at the empty ink colour.
Nov 14, 2006 | Epson Stylus C84 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
119 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
