Question about Durabrand BH1304D 13" TV
13' durabrand when i turn it on it has a screen that says eng etc.. then it says plug in cable or sattellite?? I jus want to be able to hook up my little girls leapfrog kids computer. How??
    Problem Solver:
  • 7 Answers
Re-search the remote forums. I just posted a fix using a Direct TV remote. Enjoy! :)
Posted on Feb 02, 2008
6ya staff
SOURCE:
How do i add channels on my tv
The closed caption just suddenly appeared on my screen with no buttons pressed. It won't turn off. I no longer have the original remote for this Durabrand 13" DU1301 TV . I was using the Time Warner Cable remote and have a basic cable box attached to the TV. Everything was fine until suddenly with no buttons pushed the closed caption came on. Is there anything sort of buying a new tv to fix this
Sep 11, 2011 | Durabrand DU1301 TV
How to hook up cable box, dvd player, and tv, to the home theatre system
Instructions things you'll need:
  • Composite video cable
  • TV
    • 1 Place the front left and right speakers on each side of the TV with the speaker labeled "Center" either above or below the TV screen. Set the rear speakers behind the seating area at head level and place the subwoofer on the floor a few inches away from the wall, which can absorb bass sounds if the sub is pressed against it.
    • 2 Connect the plug on the end of each speaker to the jack labeled for that speaker on the back of the Durabrand receiver. The cables are permanently attached to the speakers, so each may need to be moved closer to the receiver. For example, the left front speaker connects to the jack on the receiver labeled "LF."
    • 3 Plug the video cable from the Video OUT jack on the back of the receiver to a Video Input jack on the back of the TV.
    • 4 Plug in the Durabrand receiver and TV to the electricity and switch on both components.
    • 5 Press the "Input" button on the TV remote several times until the Durabrand signal displays on the screen.
Mar 25, 2011 | Durabrand STS98RW Theater System
My Durabrand dwt1304 was hooked up to cable. I now have relocated the TV into my workshop and am attempting to hook it up to a digital converter and an antenna. Turning the TV on, I am getting a...
I suggest to go back to the menu and make sure in the connection or signal type to select antenna.. Since you had it hooked up to cable it may not have been selected to go back to antenna. Hope this helps you out.
Feb 04, 2011 | Durabrand DWT1304 13" TV
WHERE DO YOU CONNECT A DIGITAL CONVERTER TO THE 13" DURABRAND TV?
Connect converter cable to the antenna inputs. If you need help identifying them, here is a link to the owners manual that identifies all the hook ups.
http://www.funai-corp.com/6pdf/om/DWT1905.pdf
Hope this is a Fix Ya......
Feb 20, 2009 | Durabrand DWT1905 TV
Lost my remote
Sometimes you can change the input by just clicking the channel button up >>> after the highest tv channel it'll go to Input 1, Input 2, etc. That's worked on one of my tv's but not all of them so it might work for you, too. Next suggestion would be to buy yourself a couple of universal remotes & keep them in a junk drawer for when you need one! We've found this PRICELESS!!! (Buy a couple when they're on sale & store them for those days when the remote was devoured by that oh-so-sneaky sofa!)
May 18, 2008 | Durabrand DWT1304 13" TV
Durabrand tv codes
I seem to be the only person on the net with the 3 digit Durabrand universal remote code which works for 13' and up Durabrand TV's and TV/DVD TV/VCR combos. The culprit is 3 digit code 189 for a Funai and Emerson. I only know this because I have like 4 of these TV's haha.
Ron
[email protected]
Feb 06, 2008 | Durabrand BH1304D 13" TV
Remote Control Programming
I have a durabrand tv and I lost my remote. I need to take it off of video so that I can play my Directv. I need to know how can I get Directv to play and keep the video screen off without the remote
Jan 01, 2008 | Durabrand DWT1304 13" TV
Hooking up a dvd player to my durabrand tv
If it is a durabrand dwt1304, you cannot switch the input to EXTERNAL (the front jacks) without a remote. There is a good one at Radio Shack for eight bucks, the 3-in-1 remote. The program code is 0171, and you switch the TV inputs with the A/B button.
Dec 13, 2007 | Durabrand DWT1304 13" TV
Portable DVD Dual
Switch screens on the cables. Then you will know if the problem is in the screen, or in the cable or output from your player. Check to see if the player has a source select button for the screens. Mine has the option to hook on an external source (dvd player, game console etc) and a switch determines which source goes to the screens. I.e. screen A can have the film from the internal planyer, and screen B can be used for playstation.
May 16, 2007 | Durabrand Portable DVD
Durabrand BH1304D 13" TV Logo
49 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
