Question about Kenwood KR-V990D Receiver
Have a kenwood KR-V990D and can't seem to bring the volume up
How do I raise the volume on my kenwood it goes to 00 to negative how do I raise this
    Problem Solver:
  • 11 Answers
Kenwood has always showed negative numbers 00 is as high as it will go
Posted on Jan 06, 2008
When i turn on my kenwood kr-v990d it powers up for about 2min then shuts down
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be with your output drivers. Please check for short on the outputs fitted for both the channels. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise which can be a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board. Maybe the protect circuit by itself is shutting off due to a faulty bias or there is a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the amplifier comes out of the protect mode then check for short on the speakers.
Oct 23, 2011 | Kenwood KR-V990D Receiver
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Where on the Kenwood KR-V5580 do I connect a sub woofer
Wherever the unidentified subwoofer's manual recommends. As there are no volume-controlled pre-amp outputs it would have to be a model that accepts full-range speaker level input if you want to control its volume locally.
Jul 02, 2011 | Kenwood KR-V5580
My kenwood kr v1074 reciever doesnt seem to do the job of my other reciever.....my sub is connected threw the red and black ports tried em all and my speaker just remains low volume even if i have it full...
You shouldn't hook things up and guess how they work.
BTW "KRV1074" doesn't bring up a valid link anywhere in the universe except your request.
Try finding the manual here...
http://www.kenwoodusa.com/ Use the Search box.
Mar 09, 2011 | Kenwood 107VR
Kenwood kr 3600 volume potentiometer is faulty
try google and it will give you some local electonic stores
Jun 07, 2010 | Audio Players & Recorders
Kenwood kr-v6030 master volume wont go down
To zyclon3, I've got a KR-V6030 that the volume knob some how got broke and had to take the receiver apart and get the knob out and play with it with the remote untill I got control. but I have to becareful cause it will go full blast if I'm not carefull going down in volume have to be especialy carefull since theres no stop.
Mar 08, 2010 | Kenwood Audio Players & Recorders
Sound problem
Try cleaning the volume control with an electronics switch cleaner spray. If that does not resolve the problem and it seems to happen at low volumes more than load volumes, then the output relay needs to be replaced. Keep us posted. Dan
Jun 12, 2009 | Kenwood Audio Players & Recorders
Volume control for kenwood krv5580
I was able to get the volume control to work, but how do you get an amplifiter to hook up to it?
Jan 08, 2009 | Kenwood KR-V5580
Kenwood, Very little sound for no reason!!
Check all (and I mean ALL) of your front panel buttons. It sounds like someone has pushed the tape monitor button or something like that. Be SURE to turn the volumn down BEFORE you start pushing buttons. Good luck.
Jan 31, 2007 | Kenwood KR-V990D Receiver
378 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
