Heaters
Problem for Heaters
Generic problem for all Heaters
Rheem RKKA048JK10X Furnace/AC Unit. My roo...
By advocate1 on Nov 10, 2009
Rheem RKKA048JK10X Furnace/AC Unit. My rooftop unit occasionally won't heat and shows service code #2 ''Pressure Switch or Inducer Problem Detected'' By the time a technician arrives it works fine. Happens usually in the morning (SoCal, not real cold) Any help is appreciated. Bob Miller...advocate1@earthlink.net
Best Solution
posted on Nov 13, 2009
Very Helpful)
johnsonr1
Rank: Guru
Rating: 88%, 19 votes
Mr. Miller,
It may be a problem with the tubing from the inducer to the pressure switches. During the night hours, condensation forms and collects in these tubes preventing the pressure switch from closing when the inducer motor starts. Check these tubes and possibly re-route so there is no sag in the middle. Try to route them so they are as straight as possible. If that is not possible, at the location of the sag, cut the line, put a "T" fitting in and attach a piece of line to the bottom of the tee with a plug to catch the accumulated condensation.
Also, have your service company check the firing rates, gas pressures and temperature rise across the heat exchanger, Any of these can also cause a problem with condensation accumulation in the pressure switch tubing.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Great info. I take it that the incucer is the motor that runs at start up. Btw: In the afternoon, when warm, the problem goes away. Thanks " - advocate1
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
best heater for a 5,000 square foot monolithic dome
Answer
What is the best portable heater for a 700 sq ft area
Answer
I can't change the day. It is on Sat. and today is Tuesday. The book doesn't really tell you how to... (More)
Answer
We have a larger bedroom that is always much warmer in the summer, and much cooler in the winter... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heaters Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
