Some Seiko watches have threaded back that screw on and others just snap off, the threaded ones are a pain without the proper too;s to remove it. The smart thing to do is to take it to a wal-mart and tell them you need a battery or either you need it cleaned, let them worry with it and the good thing is if they break it they buy it.
If you see the indentations on the case back to accomodate a tool, then you need that tool and unscrew counter clockwise. If you don't see those indentations then the case back then you should be able to pry by using the proper tool. You might be able to use a small bladed tool, like a knife, but be very careful that you dont slip and cut yourself. Go between the case and one of the band posts to get leverage.
I was reading the battery replacement procedures for the Garmin Forerunner 50 and have an alternate...
(More)
I was reading the battery replacement procedures for the Garmin Forerunner 50 and have an alternate observation.
To remove the spring clip that hold in the battery and plastic, place your thumb over the middle of the spring and gently press and slide the spring in a 7:30 to 1:30 direction. The spring pops out and the battery can be removed. NO PRYING IS NECESARY. Replace the battery. The spring is replaced by setting the 7:30 end in place and then sliding the 1:30 end in to lock it.(similar to the removal but in reverse). I hope this helps!
Is an Omega seamaster copy waterproof? (And this is not a Chinese cheap copy either. It appears very...
(More)
Is an Omega seamaster copy waterproof? (And this is not a Chinese cheap copy either. It appears very convincing.)
I am searching for a fusee watch crystal with following dimensions:
Diameter 46.5 mm
Internal...
(More)
Diameter 46.5 mm
Internal clearance at the center 7.5 mm
Can ytou provide this and what would be the price and turnaround?
Many thanks!
Mike Kenley
TimeOut
Worldwide watch and clock services
If it don't tick I can fix
