Question about Panasonic NV-GS35 Mini DV Digital Camcorder
No audio when trying to playback videos on pc.........have both on camcorder when played
  • Anonymous Jan 12, 2008
    I bought this camcorder for 399 dollars and then paid about 80 to get it fixed. Now that I have it , it will not place back my old mini dvd tapes.
  • porunbeso55 Jan 18, 2008
Posted on May 01, 2008
I mean , it will not play with sound. The picture is good but there is not sound
Posted on Jan 12, 2008
How do I fix audio on playback
Check cables, change cables, try playing it in another camcorder, if it sounds the same than ur camcorder recording is no good.
Mar 15, 2016 | Video Cameras
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
I am trying to playback videos on my JVC Everio Camcorder using the colored AV cords. I hear the audio coming through my TV but there is no video/picture. I have tried adjusting the settings and tried...
then turn off the (camcorder) unit.
After you connect the cable (from AV connector to the TV's AV Input Connector (accepting the 3 color cables), set the TV to VIDEO mode, selecting the AV input (from your Camcorder).
Then start your playback on the camcorder ...
slide the mode switch to select the (video) mode (instead of the picture/photo mode)... press the PLAY/REC to select the playback mode, and select the desired files/frames to play.
Hope this works for you. Have you tried using the HDMI mini connector instead ? (same process, just set your TV to accept input from the HDMI input)
Jun 03, 2014 | Video Cameras
I have the above model camcorder ,the playback on my laptop with windows vista is terribly poor jumping all the time/distorted with jvc software provided or on windows media player it plays but audio is...
Are you playing the video directly form the hard disk in the camcorder or are you transferring the file to the laptop first? Reading high volumes of data via USB is slow and the PC may not be able to read the data fast enough from the camcorder. Try copying the video to the laptop first, then play it back.
Feb 20, 2011 | JVC Everio GZHD500 High Definition AVCHD...
Playback on PC has no sound
Are you playing the video back through the camcorders utility ? Sometimes by clicking on the file through windows explorer you will get the picture but no sound, this happens for the Sony camcorder but is fixed by running the playback through the motion picture browser application supplied with the camcorder.
Oct 24, 2008 | JVC Everio GZ-MG360 HDD Camcorder
No Sound
The camcorder may be in what may be called "narration mode." This function mutes the playback audio so you can narrate with you own voice when playing tapes back. Check for a function like this in the playback sound menu.
Nov 06, 2007 | Panasonic NV-DS60 Mini DV Digital...
No sound when playing back video
I had the same problem. Try this: open the LCD screen so that you can access the playback buttons.Make sure camera is in playback mode. Press the "menu" button. Select "narration" . Switch narration to "off" .Now you should hear the recorded audio when your tape is playing.
Jan 03, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
How do I play MPEG recordings?
Using Windows Media Player You need Microsoft Windows Media Player Version 9 or higher and Sharp G.726 Audio Codec in order to play MPEG4 files from the Memory Stick on your PC. If you are not currently using Microsoft Windows Media Player Version 9 or higher. Important: The Sharp G.726 Audio Codec needed to play MPEG4 files is no longer signed by Microsoft. If Sharp G.726 Audio Codec is not properly installed on your PC, it will not play MPEG4 Audio. Using DivX® You can also download a free DivX® Player and codec to play your MPEG and other video format files. DivX® for Windows is a free codec built to play every version of DivX content. The DivX codec also plugs into your existing video software so you can view and create high-quality DivX videos at a fraction of the original size. The DivX codec also adds DivX video playback support to most popular media players.
Video playback is not smooth while playing via USB 1.1
USB1.1 port can generally handle transfer speeds approaching 5.5Mbps between PC and DVD Camcorder. Smooth playback of movies requires 5.5Mbps speeds or above. If the PC you are using has some compatibility issues with the USB driver software, the USB port may drop to speeds below 5.5Mbps causing short pauses during video playback. It is recommended to copy the movie file from the DVD Camcorder to the hard disc drive (HDD) on your PC, then playback the movie from the hard drive.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Panasonic NV-GS35 Mini DV Digital Camcorder Logo
51 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
