Question about Sony KP-57WS500 57" Rear Projection Television
Red lines and turns off and stand by light stays on
I have taken the red tub out and replaced it and made all put all da plugs in and now when i turn it on i see red lines and then it turns off when i look at all the light they all light up but before the red didnt now it does and it still wont stay on. what els can i do or replace wat is my problem
  • Sony Master
  • 8,617 Answers
You are going to need a service manual to trouble shoot your set. You can get one at the folloeing link along with online support. http://servicemanuals.vstore.ca/
Posted on Jan 10, 2008
New replacement in-line heater (C3B54P0-3002AU0) inop.
Bath tub heaters will only maintain the water temperature in the bath. They will only heat the water approximately 1-2 degrees an hour.
Whatever water temperature you start with is what you will be able to maintain.
There is a red indicator light on the front of each heater indicating whether or not there is power to the unit when the tub is full of water and the water pump is turned on.
If there is a red light on then it has power to it and is working.
This heater will never feel warm to the touch.
There are three different styles of Bath Heaters available.
  • Tee Heater - installs on the discharge fitting on the pump
  • In-line Pressure - installs anywhere in the plumbing line before any jet.
  • In-line Vacuum Heater - installs before the suction of the pump
If the heater you purchased is installed in the wrong place it will not operate.
Rod
US Parts Center
Dec 04, 2013 | Maax Calla 6042 Bathtub - 101058-000
My converter box will not turn on. The light stays red. i plug it in and it lights red but it wont turn on it stays off and i use remote and i manually push the power button but it wont turn on!!
TRY
Unplug receiver.
Leave for 10mins.
Plug in again.
Wait another 10 mins.
Press the hand control stand by button.
In a few minutes the light should turn green and start options should appear.
Good luck. This works when my HD box freezes.
Feb 02, 2010 | Televison & Video
WHEN I TURN ON TV I GET A RED SCREEN WITH HORIZONTIAL LINES STAYS ON FOR 10-15 SECONDS THEN TURNS OFF STAND BY LIGHT BLINKS 7 TIMES SORRY THIS IS A SONY KV35V65 TV
this is a red retras line problum
[1] red cathoud video amp. trangester is sort or dry canaction
[2] red cathoud is sorting with filament terminal is in side pictur tube
so pls. cont. your nr. tv. tech. solve this problum. it is not very expancive
* this is a coman problum if your tv set is 7 to 8 year old.
Nov 10, 2009 | Sony KV-32V65 TV
Red Light Flashes twice KDF-E50A10
Are you putting the lamp cover back in place before trying to turn the set on? The 2 blink error is a temperature error you might want to check the thermal sensor, is your lamp door warped?
Oct 30, 2009 | Sony KDF-50E2000 50" HDTV
Interrior lights stay on
are your dasboard lights at full brightness?Turn your headlight switch(it may be on the interior light detent).BTW I drive a '97 Bonneville SE and one great thing about these cars is that if you leave a light on it will shut off after about 5 minutes so it won't drain your battery overnight.
Oct 04, 2009 | 1997 Pontiac Bonneville
Nothing is showing on the monitor
just your monitor back panel open next monitor neck board put dry solder
Sep 26, 2009 | Compaq Computers & Internet
Screen won't turn on. Red light showing it is off does work.
My plasma is on stand by mode,. It went off during a movie. It will not turn on when I press the power button, it only stays on stand by
May 22, 2009 | byD sign 4032 40 in. HD-Ready LCD...
Stand by light stays on only black screen
mainboard damaged.
replace the mainboard and that should solve your problem.
May 09, 2009 | LG 47LG50 47 in. LCD HDTV
Sony KP-57WS500 57" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
