The unit keeps filling until water leaks from the door. Unless we hit the stop button the machine seems to be willing to keep filling, even while it is in 'drain' mode. I removed a quarter from the drain pump and once I put it back together and we ran the first load through it, this problem materialized and I cannot stop it..
if this problem was not present at the start.what was the problem ?as i dont know, im going to tell you what i think?from experience of all white goods i always start at the control switch; your programme;your controler sounds as if it needs tested its what is known as a dry joint its a quick test and should not cost much and a quick saulder should fix it.adrian;;;;
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune Front Loading
I have the maytag neptune stackable washer, dryer, it does not spin, I have had 3 people look at it....
(More)
I have the maytag neptune stackable washer, dryer, it does not spin, I have had 3 people look at it. None can figure it out. Please Help. The wash runs up to the spin cycle then just stops.
Maytag model MAH3000 won't shut off after final rinse. Trouble shooting document in washer control...
(More)
Maytag model MAH3000 won't shut off after final rinse. Trouble shooting document in washer control panel says ''End of cycle signal ON/OFF'' Machine control connector/wire = P5 (WH11) & P2 / 1 (PU21) 24VDc ON O Vdc OFF; Timer Contract = Not Involved. Does this mean the board is bad because the Timer is not involved?
The unit keeps filling until water leaks from the door. Unless we hit the stop button the machine...
(More)
