Fix mouse Hi- I have a Logitech VX Revolution mouse. The small red wire that goes to one of the battery clips has broken. I need to open the case of the mouse to get to the very short wire in order to solder it. I can't get the case open as there are no screws (that I can see) on the back of the mouse. Can you tell me how to get it open? Thanks, Hank Mackie
Most mice these days are heat or epoxy sealed. There is no real hope of getting inside of them to service them at all. The only place that could be hiding any screws would be under the teflon pads, but it's becoming a much less used method to assemble mice.
Posted on Jan 06, 2008
6ya staff
SOURCE:
MY LOGITECH MX REVOLUTION MOUSE NOT RESPOND
There are a number of reasons why your mouse isn't reponding:
  1. Check that the batteries are full
  2. Check that the mouse is synchronised with the adapter
  3. Check you have the correct drivers installed.
If none of these things help you, then if your mouse is still under warranty, I'd ask for another one.
Good luck! John
Mar 13, 2011 | Logitech VX Revolution 931690-0403 Mouse
Mouse will not charge when put in the base
I have a very bad solution about this, but it works on my mouse that also doesn't work. Try to put a tiny bit of water ( or spit Oo ) on the little, usually copper, receivers on the mouse. That makes for a better contact. Just get your finger wet and touch those receivers.
May 15, 2010 | Computers & Internet
HI vx revolution mouse repair
no sorry, once the little pins and rollers inside have broken their isn't any way. I'm really sorry.
Dec 25, 2009 | Logitech VX Revolution 931690-0403 Mouse
Need to replace the battery in a Logitech MX Revolution Mouse
Hello. Yes, it is quite simple to remove the battery of a Logitech MX Revolution mouse yet for some reason when going through the Logitech product support website it states that it is not possible. Just remove the 4 teflon pads located on the bottom of the mouse and then remove the four screws located under the pads. Once this is done turn the mouse back upright and remove the top off of the mouse. I would suggest temporarily removing the flex cable that holds the top and bottom of the mouse together. There is a small metal clip that holds the battery in place that must now be removed.
NOW FOR THE VERY IMPORTANT PART. There are two different generations of the Logitech MX Revolution mouse which have different batteries. The first Generation uses the L-LY11 battery and the newer generation of the MX Revolution uses the L-LL11 battery. There is no way to tell which battery your mouse uses without first opening up the mouse. Once opened you can easily tell which battery your mouse uses. Here is a link to a site that shows you an example of the L-LY11 battery: MX Revolution L-LY11 Battery
Here is a link to a site that shows you an example of the L-LL11 battery: L-LL11 Battery for Logitech MX Revolution Mouse
As you can see the L-LY11 battery has wires and a plastic connector and the L-LL11 battery has contacts. You should definitely determine which battery your mouse uses ahead of time to eliminate any frustration caused by ordering the wrong battery ahead of time.
Sep 12, 2009 | Logitech MX Revolution Wireless Laser...
Wrong Receiver for Logitech Vx Revolution Mouse
logitech has connection software on their site you need to run
Jul 07, 2009 | Logitech VX Revolution 931690-0403 Mouse
Regarding the VX revolution mouse
Hi. Partial / Potential solution:
I think there are screws holding the mouse together, and that they are located under the 'plastic' pads on the bottom of the mouse. On mine, the pad directly behind where the battery goes (towards the 'tail' of the mouse / palm of hand) popped off easily to reveal a screw that came out easily enough. The other pads are stickier, tho, so for me it's not worth trying to mess with them now. If it gets worse, I'll take them off and see what's to see. If yours is pretty bad, it might be worth it. Cheers...
Jan 01, 2009 | Logitech Wireless VX Revolution Laser ...
VX Revolution Cordless Mouse for Notebooks dead as a door nail...
I see no reason that the mouse should not work. They have the Xop driver and the install software. Download both and also read henote that they are talking about in. red. I didn not download it myself. If this doesn't work you can get a common PS 2 mouse for a small amount  most anywhere including Walmart.
http://www.logitech.com/index.cfm/428/165&cl=us,en?softwareid=4338&osid=1
Dec 30, 2008 | Logitech Cordless Mouse
Battery
Not sure how your mouse is configured but will give you two possibilities to use.
Turn your mouse over and see if there is a small door on the bottom where the batteries are located.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Aug 21, 2008 | Logitech MX Revolution Mouse
Open Questions:
BroTheR PrinTeR CusTomeR SeRviCe pHoNe#{@+1~888~589~0410}nUmBeR Texas USA Brother Printer Customer Service [email protected]+1~888~589~0410 Texas USA Brother Printer SuPpoRT Number Brother Printer SuPpoRT phone Number Brother Printer TeCh SuPpoRT Number to resolve all Brother Printer products. Brother Printer is an American multinational company which was founded by Michael Brother Printer using its company headquarters in Round Rock, United States of America. Contact Brother Printer for Setup & Installation Brother Printer Setup Free & Installation Brother Printer TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Brother Printer Connect setup for Windows and for Mac. So, right here we go VIKKI. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Brother Printer Connect, Brother Printer TECH Free Phone Number you'll be searching out Brother Printer Connect setup as well. So, here we're with all cthe setup process and for your to Brother Printer Connect. Get Brother Printer Setup Instant Free Brother Printer TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again.
Nov 12, 2019 | Brother Computers & Internet
AOL MAil SuPPoRt NuMbER [+]{1+/855+/536+/5666-} FLORIDA $%^^}#[email protected] call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
Nov 12, 2019 | AOL Computers & Internet
Computers & Internet Logo
369 people viewed this question
Ekse
Marvin
Marvin
