PC Desktops
Problem for PC Desktops
Generic problem for all PC Desktops
I just put together a pc for my little gir...
By waters_k on Nov 10, 2009
I just put together a pc for my little girl. Everything seems to be hooked up right as far as I can tell. The pc is getting power, lights on, cpu fan is spinning, video card fan is spinning, but the pc fan doesnt work nor does the cdrom. I've checked and double checked all the connections but still the same. In the bios none of the drives are showing up either. Is this some sort of power issue? It is all the same parts I have used together before without any probs, but this time it's just not working.
Solution #1
posted on Nov 10, 2009
Not Rated)
swDemonDog
Rank: Guru
Rating: 87%, 24 votes
Have a close look at the power pig tails.
Since you state both PC fan and cdrom does not work.
I would suspect no power is getting to these. It is rather difficult to plug in the ribbon cables wrong. They will only go one way. :)
As vinayT suggests, run the auto detect in the bios for the MB to read the drives. When the machine is powered on, check the lights on the drives to see if they light up briefly.
Loose connection can also cause the CDrom drive to fail.
Wiggling around in those tight spaces you can easily pull something loose without realizing. Triple check all the connections and those power plugs. Make sure they are running to the power supply and 12V! Swap power pig tails, if something else stops it means that power plug is not delivering.
Be sure to let us know what the problem was. :)
We are a curious bunch.
Was this helpful?
Yes
No
Solution #2
Not Rated)
VinayT
Rank: Wiz  Computer Hardware  Expert
Rating: 81%, 855 votes
If they are not showing in the BIOS then your cable may be connected incorrectly. Check the red line on the ribbon cable connecting the HDD and DVD drive to the motherboard is towards number 1 pin. Also have you tried auto detect in BIOS?
Was this helpful?
Yes
No
Popular Solutions for PC Desktops
Questions and Unsolved Problems for PC Desktops
Answer
what is the price for microsoft notebook receiver v2.0
Answer
Cameras Sharp sharp ar-5316-paint the No. 2 Li* + box I would like to send Machinery until you... (More)
Answer
when i try to format my computer it is ok but i try to install a software it doesn't continue but if... (More)
Answer
phone memory requires security code please help
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Desktops:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
