Question about NMB Technologies Fan Motor Case Cooling Fan
FAN MOTOR FOR 1995 MERCURY COUGAR XR-7
THE BATTERY LIGHT COMES ON WHEN YOU ACCELERATE. THE FAN MOTOR IS NOT WORKING. IS THIS WHY THE BATTERY LIGHT COMES ON? TO BUY A NEW FAN MOTOR IS THERE ANOTHER PART THAT YOU NEED TO BUY
  • 27 Answers
If the fan is electric it may just not be running when the engine is cool enough. Be sure to check it when your engine is hot, after you've been driving for a while. The battery may have a bad connection somewhere. Can the battery move when your accelerating? If so you should repair/replace the mounting hardware for the battery. Check the wires and connections to/from the battery and tighten/clean anything that is loose or dirty.
Posted on Jan 08, 2008
My blower motor works intermittently/ whenever it feels like it. When it decides to, everything works as it should. It's on a 1997 Mercury Cougar XR 7 4.6 V8
I have run across this many times it is caused by the blower having worn brushes, replace the blower motor and check the connector for signs of burning, replace the connector if it seems burned. If you need the blower motor connector you can buy it from Ford, solder it in DO NOT USE CRIMP CONNECTORS! Shrink tube the solder joints.
Nov 23, 2016 | Mercury Cars & Trucks
1997 mercury cougar xr-7 alarm won't work after I replace the car battery (well Pep-Boys replaced the battery). My alarm won't activate.
after replacing the battery ,to overcome problems try resetting the CPU program with a scanner.
Aug 15, 2014 | Cars & Trucks
I need to pass my emission test ASAP. How can i reset my engine light? WITHOUT having something repaired 1995 Mercury Cougar v8
disconnecting your battery for about 10 minutes will clear the codes but if it comes back youll need to fix the issue. in indiana pre 97 cars the check engine light wont fail you
Aug 26, 2011 | 1995 Mercury Cougar
I HAVE A 1995 MERCURY COUGAR XR7, BOSTONIAN EDITION. PROD DATE OF 7/95 I NEED TO REPLACE THE BACK BRAKE LIGHT/TAIL LIGHT LENS. IT IS ON THE TRUNK ITSELF. I'M GOING CRAZY TRYING TO FIND OUT WHERE TO FIND...
1990 Mercury Cougar Bostonian, mint condition... recently purchased. I hear a whisting/slight high pitch noise that seems to be coming from, in back of the glove box. Any suggestions or ideas?
Mar 14, 2011 | 1995 Mercury Cougar
Looking for the plug connections for an alternator for 1995 cougar xr 7 4.6L/v8
Autozone has a line of repair connectors available, check them out
Dec 28, 2010 | 1995 Mercury Cougar
Replacing the starter on 95 mercury cougar
its on the driver side of the motor on the botton there no easy way to change it make sure u undo the battery
Jul 30, 2010 | 1995 Mercury Cougar
1993 Mercury Cougar XR-7 V-6, Overheating
Your problem could be the coolant temp sensor, or it could be the gauge itself, but something 2 do is if you can get it to a dealer, or a parts store. If you cant get it there, you can get an OBD I scanner and retrieve the code and know why the check engine light is on, but it could be from any of the sensors on the car, would be best to get it scanned.
Apr 12, 2010 | 1993 Mercury Cougar
!993 Mercury Cougar XR-7 3.6 V6
If you are referring to the Check Engine light then this indicates there is a problem with the emissions system. Have the ECU scanned with an OBD2 scan tool. The fault code that has been set by the ECU will tell you where to look for the problem. If the engine is running fine there is no hurry, but do have this looked into. If you are referring to the oil pressure light stop driving the car until you get this repaired as it may be serious.
Mar 21, 2010 | 2000 Mercury Cougar
My 1193 Cougar XR-7 revvs up when driving close to
Sounds like a synchoniser has gone kaput!
Feb 03, 2010 | 1993 Mercury Cougar
Code 1443 Mercury Cougar XR-7 4.6 Ltr engine (Check Engine Light is on)
it depends on which letter is in front of the code
B1443 is door handle switch circuit open
C1443 steering phase Acircui short to ground
P1443 evaporative emission system control valve ( low / no flow )
hope this is what you ar looking for
Oct 10, 2008 | 1996 Mercury Cougar XR7
NMB Technologies Fan Motor Case Cooling Fan Logo
172 people viewed this question
Top NMB Technologies Computers & Internet Experts
David Payne
David Payne
Are you a NMB Technologies Computer and Internet Expert? Answer questions, earn points and help others
