Problem for Kitchen Ranges
Generic problem for all Kitchen Ranges
The macine doesn't go through spin cycle.
when the timer reaches the spin cycle, there is a clunking noise and no spin or water spray. just resently replaced the timer.
Clarification Request
Posted by oldguy5 on Nov 10, 2009
Can you provide the exact Make, Model and Kenmore model number? Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.
Solution #1
posted on Nov 10, 2009
Rank: Guru
Rating: 87%, 18 votes
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
If it doesn't spin or pump, it could be that
your pump is seized or something is stuck in it. The agitator is operated by a
different motor. Turn OFF the power. and remove the front vertical panel by
inserting a drywall knife in a the top right about 4" in from edge at the
joint 1" down from the top, push the clip towards the back of the machine
to release that corner, get another knife and do the same to the left top
corner, the pull the top of the front panel toward you and swing down, then
lift off and remove. Disconnectt the two hoses to the pump, one from the
drum the other that goes to the back. Be ready for a considerable amount
of water to come gushing out, use a hose to direct to a floor drain.
Check to see if something is stuck in the pump or the hoses, remove it.
Check to be sure the impeller spins. If you found something restricting
the flow or pump, remove it and re assemble. If the impeller won't spin
easily, then you need a new pump.
Remove blockage in the pump. Re-assemble and test.
Popular Solutions for Kitchen Ranges
GE Profile Spectra JGBP90 Gas Kitchen Range
1 Solution
KitchenAid KESC307 Electric Kitchen Range
1 Solution
GE Spectra JBP78 Electric Kitchen Range
1 Solution
Questions and Unsolved Problems for Kitchen Ranges
Basic electic stove with no bells or whistles - Tappan, Roper or Whirlpool?
which brand Dual fuel slide in range is the best?
Maytag mer5765rcs was on broil, heard a loud pop and the oven filled with smoke. Also at the same...
(More)
Maytag mer5765rcs was on broil, heard a loud pop and the oven filled with smoke. Also at the same time lost all functions on the control panel.
I have a Maytag range. The problem is the Oven. It works at first, comes up to temperature then it...
(More)
I have a Maytag range. The problem is the Oven. It works at first, comes up to temperature then it does not maintain the tempeture. It gradually get cooler and cooler. It becomes a warmer. I think the problem my be the igniter and was think of replacing it but I was not sure since it does ignite upon start up. If I turn it off then on again to a hotter tempature I can usually get it to kick on again.
The oven worked this morning. Now will not fire up? Power on.
